Cab Bushing HELL.......Advice please?
I have 1 brand new set of body bushings setting between the frame of a 70
4x4 and cab. I have 67 step that is getting the cab from the 4x4. I went to drop the cab onto the 67 frame today and SURPRISE! the cab mounts on the frame are different. The front mounts are the same, but the rear mounts on the frame are different. The 67 rear cab mount is level with the frame rail. The 70 rear cab mount is dropped down on the frame rail about "1 1/2. .......So, the rear cab body bushing is taller by about an inch an a half as well. Fronts are fine and line up well. So, anyone else encounter this? and WHAT SHOULD I DO ABOUT IT? Thanks. (***Note: to those who want to flame me for not building the 4x4, the whole 4x4 frame is a total hack job. Rears dont align with transfer case, no brake lines, custom springs that are a mess...etc. but thye cab was good. The 67 frame was already finished when I bought the 70.) |
member #16
![]() Join Date: Dec 1999
Re: Cab Bushing HELL.......Advice please?
I believe the C & K models use different mounts.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Resident Curmudgeon
You will need 2wd C10 cab mounts, you have 4wd and/or 2wd C20/30 cab mounts currently.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
its all about the +6 inches
4 x 4 and 3/4 ton, and one tons all use the tall mount.
The 2 wheel drive 1/2 ton uses the odd ball short mount. |
