Old 11-05-2008, 07:21 PM   #1
cparman
sharp as a marble
A Bagged question
I know absolutly nothing about Baggs, and want to know why I cannot do this. 1972 Blazer 2wd, has someones drop springs in it. sits pretty level when the top is on, but raises a bunch with the top off. I am wondering what would happen if I bagged the back, and ran lines to a air fitting. no compressor, not tank, just baggs, and adjusted the air pressure to set ride height. Kind of like air shocks. I am not into the layin frame thing, just want the 2wd to ride level ---top on, and top off..HOW DO I DO THIS SIMPLY..
thanks in advance
cparman is offline   Reply With Quote
Old 11-05-2008, 08:34 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: A Bagged question
Yes, you can do that. You say it's a 2wd, so I "assume" it has trailing arms in the rear. If so, all you need is to bolt the bags to the spring pads. You can use single air lines, or T them and run a schrader valve.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-05-2008, 11:08 PM   #3
Ackattack
Ackattack's Avatar
I'm not running a compressor and tank on mine (going to race it, and that stuff adds $$$ and weight). If you go to napa, you can get a "tank valve". It's a schrader valve with NPT threads on the other end. Then you just need the appropriate fitting for the size of airline you're running.
I did not T my lines together. The reason why is I was concerned about air basically moving from side to side around corners and causing problems that way. I figure i'll just use a tire pressure gauge to "level" it or eyeball it.
Ackattack is offline   Reply With Quote
Old 11-06-2008, 12:37 AM   #4
FnLow69
FnLow69's Avatar
you can "T" them together but you'll need something to prevent transfer during cornering, a simple ball valve on either side of the "T" would work. you can open them and air it up than close them after...
FnLow69 is offline   Reply With Quote
Old 11-06-2008, 08:23 AM   #5
cparman
sharp as a marble
Thanks to all! will get started soon
Hey FNLOW69 Do I need a ball valve if I use two schrader fittings & check my signature!!
I was born the day James Dean died
Old 11-06-2008, 10:19 AM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
This is how my truck is set up. Works well.
Originally Posted by cparman View Post
Do I need a ball valve if I use two schrader fittings...
No, as long as they are isolated from each other, you're fine But linking them together will allow you to get the pressure equal, and therefore level, then just close the valve...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-06-2008, 11:35 AM   #7
FnLow69
FnLow69's Avatar
haha did see that, cool. i was born on elvis' b-day just 51 years after him...
Old 11-07-2008, 07:18 PM   #8
cparman
sharp as a marble
Thanks to all who posted. NOW if you guys would tell me wher to buy, and what to buy, my 2wd would sit level soon with the top off!!
Old 11-07-2008, 09:04 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Use Slam Specialties RE7 bags. Alot of places sell them. I got mine from Nathan Porter of Porterbuilt Street Rods. Plus he's a supporting board vendor. Shoot him a PM.
Keith
Convert to disc brakes.
Old 11-08-2008, 03:57 PM   #10
ENHANCED AIR RIDE
I would use two schraeders mount them side by side real easy to adjust. We just did a 70 Monte Carlo SS 454 and put the whole car on 4 schraeders. I really like the Air Lift Dominators as far as ride quality. I can help you out if wanted.
Good luck!
ENHANCED AIR RIDE is offline   Reply With Quote
