Old 11-05-2008, 07:39 PM   #1
steppside69
steppside69's Avatar
Question drop spindles
I have 2 quick questions and hope you guys can help me,
#1 I was wondering if I bought air bags for my truck (69 chevy) with stock spindles and drum front brakes, Would or are there any issues with keeping the stock components on the truck with bags?
#2 Is there a conversion for 6 lug disk brakes from another truck that is available at a junkyard, That is a direct replacement? Is there any trucks that have bags that are stock suspensions besides the bags? Thanks for the help
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 11-05-2008, 08:39 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: drop spindles
The most common way to do the disc brake conversion is to use a 73-87 components. You can drop the entire crossmember and bolt it under your truck, or break it down piece by piece. This is the easiest "junkyard" solution, but it will give you 5 lug rotors.
If your really want to keep the six lug rotors, there are several forum vendors that sell the kit to replace your drum to disc 6 lug.
Yes, you can put bags in place of your springs and not use any other lowering components. Essentially you replace the coil spring with an air spring (bag).
Any reason why you want to do one with out the other?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-06-2008, 01:30 AM   #3
VA72C10
VA72C10
VA72C10's Avatar
Re: drop spindles
Anyone done the drop w/bags and front drums w/out putting drop spindles on? Interested how low it can get in the front. Seems like a good cheap way to do it esp. with schraeder valves.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-06-2008, 07:06 PM   #4
steppside69
Re: drop spindles
Thanks for the info, The only reason I was asking was to see if anyone has done it and just the tighta$$ in me. I can afford to do one or the other, and I am debating the brakes or the bags first! I was going with the bags just because the look is immediate and cool
I was asking about the (junkyard) disk swap because if I have enough drop that I'm happy with then I might not want to do the drop spindles. I have to admit that looking at all the trucks here are really motivating me to go lower!!
Thanks, steppside69
Old 11-06-2008, 07:58 PM   #5
steppside69
Re: drop spindles
just looking @ slam specialties, wondering if sleeve bags or regular in the rear?prices seem reasonable. Anything I need to beaware of getting stuff from them? Thanks steppside69
Old 11-06-2008, 09:05 PM   #6
pissonNOS
senior member
pissonNOS's Avatar
Re: drop spindles
I did this and i will admit i was like you in that start but after about 2 carshows of having to fill the bags with a tank and check them with a tire pressure guage i soon got tired of it, if you can afford it do it all at once and with the drums and bags i was about an inch above the tire with the fender now im an inch under
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 11-06-2008, 09:41 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
Re: drop spindles
I already got two compressors I got a decent deal on....Now looking for a good deal on the bags and the valves. I will probably do it w/out the spindles on my 70 because I plan to eventually sell that and find another project.
Old 11-07-2008, 10:09 AM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Re: drop spindles
Here's a JY way of converting to 6-lug discs from a late model chevy truck posted by FirstGen:
1968 C20 lower control arms
1990 3/4 ton Light Duty 2X4 must have (1.25" rotors) spindles
1990 1.25" thick 6 lug rotors
1990 calipers off same truck
1990 upper and lower ball joints
1990 outer tie rods
inner tie rods MOOG part #ES2020RL
1990 style tie rod coupler
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-08-2008, 04:00 PM   #9
ENHANCED AIR RIDE
Re: drop spindles
Hello
Yes if you want to keep 6 lug and add disc later, no problem. Same for doing a drop spindle, can add later. The sleeve bags ride the best but will not go as low as the convoluted in the stock location. LMK if I can help
ENHANCED AIR RIDE is offline   Reply With Quote
Old 11-08-2008, 11:43 PM   #10
baggedcten
86 C10
baggedcten's Avatar
Re: drop spindles
they are a great company to work with.
1986 C10
2001 chevy silverado purchased 8-29-09 sold
2004 silverado purchased 8-27-10 sold
baggedcten is offline   Reply With Quote
Old 11-12-2008, 07:54 PM   #11
steppside69
Re: drop spindles
Thanks for the replys, I was wondering if there is a difference in the ride quality of the different bags?
Can you tell a noticeable difference from coils to bags? I like the look of the drop but think the coils give a pretty good ride and was wondering if I could tell the difference.
Old 11-12-2008, 11:29 PM   #12
VA72C10
VA72C10
VA72C10's Avatar
Re: drop spindles
I have heard the slams are performance oriented ( a little stiffer ride) and the dominators and firestones are a more cushy ride. But i'm sure others w/ the bags already installed can add a more informed opinion
