Old 11-05-2008, 08:40 PM   #1
454c20
Annoying Rear End Vibe
Well I narrowed down my vibration at speeds over 55+. It seems to be coming from the back of the truck somewhere as I can duplicate it on jackstands.
So far, I have swapped the rear rims/tires, had a entirely new driveshaft made and balanced (old one was bent), and I just pulled the rear apart to check it over. All the bearings look fine. It seemed both axle shafts had some excessive runnout so I replaced those as well. I'd have to say after all that there is little to no change in th vibration.
What else can it be? The only things I havent physically touched is the actual rear end housing and tailshaft bushing in the transfer case.
Any thoughts? I'm getting tired of putting money into it w/o any changes.
Nick
'87 1/2ton 4wd-mild 355, TH400, long tubes, 3" single Magnaflow, manual locking hubs
'88 SS-built 357, 2004r, 9.5" 3200 stall, 4.10 posi 8.5
'94 9C1-174k, built 4L60e, Hughes 2500 stall, 3.73 posi, 93oct tune, 2.5" true duals
454c20 is offline   Reply With Quote
Old 11-05-2008, 10:11 PM   #2
va_tlc
va_tlc's Avatar
Re: Annoying Rear End Vibe
well i had same thing, i rebuilt transmission, then like you a brand new driveshaft made and new slip yoke, still noisy, so took rear end cover off and jacked wheels up and found about 3 teeth off .. not a good start on this truck.
so orederd a new ring gear and pinon, also changed pinion yoke i guess ya call it, the one on ya rearend that holds the driveshaft. you may wanna check that mine was spread and the lil metal tabs that holds the u joint in place was wore about off. hope you have better luck than i did.
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 11-06-2008, 05:22 AM   #3
454c20
The gears looked fine, although the backlash was a little looser then I like to see it. It was between 0.012 and 0.013, while spec is 0.006-.0010.
Anyone in the MA area have a cheap 10 bolt for sale?
Nick
Old 11-06-2008, 10:25 PM   #4
va_tlc
va_tlc's Avatar
careful, you have to be a paid member to post a want to buy, and trust me it will be the best 25 bucks youll spend, youll also be able to sell things,hum back to your problem did ya check u joint too? do you have a lift kit in this truck? good luck
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
