73-87 upgrades for 67-72 pickups.
Hi all!
I have a 72 c20 I have a few 73-87 upgrades done to my truck. Most of these upgrades were done by a friend of mine that I purchased the truck off of. First the coil springs and trailing arms are gone in place is leafs and a rear with a locker with fairly high gears for highway speeds. power steering box and pump also from 73-87 pickup the big steering wheel with the newer ps almost turns too good. accelerator pedal and cable from 73-87 also no more sticking throttle. I am really interested in power brakes i have spindle caliper and rotor assembly once i figure out which ball joints im wanting to try this upgrade im just wondering is there anymore 73-87 upgrades similar to these sometimes i wonder if im wasting my time or should i just put this body on a 73-87 frame! |
Dave's not here, man
Re: 73-87 upgrades for 67-72 pickups.
I did an 88-91 'Burb brake upgrade on my 68. The swap wasn't too bad. I used the stock crossmember with the burb a-arms, spindles, bj's, tie rods, centerlink, blah, blah, blah. I also used the booster/master. Had to slot the holes to make it clear the hood. Stock rear brake hardline fit into the newer master cylinder. Had to re-use the front hard line from the burb and route it. As for other upgrades, I'm not too sure. That's the only one my truck has seen from a newer truck thus far. I'm sure some others will chime in with their experiences. BTW,
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Cool! Thanks for the reply to my post. I cant wait to get some discs on my old beater!
There`s really not much different between 67/72 and 73/87s.Those added things were all available and no different on the earlier trucks.All 68/72 trucks steer way easy with p/s.Power brakes can be swapped out of any GM light truck.Same with disc brakes.I definately wouldn`t swap frames.The frame itself does have differences.
thanks as i mentioned i have a c20 but i have found a donor 77 half ton pickup is there any differences in the brake booster master cylinder and proportioning valves? i really want to use the pedal out of it also!
Sierra Grande Club
I wouldn't consider replacing trailing arms/coil springs to leafs springs an up grade.....
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
That really depends on what he wants the truck to do. Coils and trailing arms are much better for acceleration/traction and handling while the leafs are better for load carrying. I haul a ton of stuff but I like the arms and coils...wouldn't trade 'em cause of the handling and power transfer advantages.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 11-09-2008 at 11:21 AM. |
Sierra Grande Club
I agree with that... I'm sure newer leaf springs are better (ride wise) than what was available on our 67-72's.
s/t
I was going to try the whole body swap thing onto an 80 half ton frame but found that the wheelbase was about three inches longer and it would have been a real pain in the butt to deal with. I did find that the whole front suspension is the same, steering box and all. So, what I am going to do is transplant all that into mine. As for the rear axel, someone on here gave me a website to get all the brackets to switch a leaf spring axel over to trailing arms. If you need, let me know and i will get you the add. Anyway, I like the trailing arms better for the ride. For hauling, not so much. But that is a call you have to make. Good luck.
The truck rides like a dump truck but has hauled ALOT of junk!!!!!
