Old 11-05-2008, 09:18 PM   #1
azsmokey
GEN III EFI/Fuel Tank Questions
To all of you who have installed fuel injection into your 67-72, what type of tank setup are you using? I have seen a number of different variants from CPP, ECE, etc... What else is out there? I do not really want to spend a lot of $ on the tank alone. Rick's Hot Rod Shop quoted over $1000.00 for just the tank! Lets see pics... Any ideas?
azsmokey is offline   Reply With Quote
Old 11-05-2008, 09:21 PM   #2
killer71
killer71's Avatar
Re: GEN III EFI/Fuel Tank Questions
contact boardmember "fuelcellguy" and he can help ya out. i have actually used him on 2 difft. occasions and he's a gr8 guy to deal with.
http://67-72chevytrucks.com/vboard/s...d.php?t=244448
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 11-05-2008, 11:07 PM   #3
boostat4500
I am using my stock tank with an in-tank pump. Mounted the regulator just outside the tank and ran 1 fuel line up to the motor. Inexpensive and easy!
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 11-05-2008, 11:47 PM   #4
killer71
killer71's Avatar
nice job boostat 4500, that would save him a ton of money!
R.I.P.
Killer 71
10/26/07
Old 11-06-2008, 12:08 AM   #5
jorgensensc
jorgensensc's Avatar
What do you do about low fuel starving the engine on corners?
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-06-2008, 01:08 AM   #6
RamAirZ
Keep it full of gas And don't autocross it lol
1967 Chevy K10- 4WD project in the works -sold
1985 Suburban- 1/2 ton w/ 3/4 ton gear, 350/700R4 33's and big!
1987 Iroc- LS1/T56 conversion- sold
RamAirZ is offline   Reply With Quote
Old 11-06-2008, 01:30 AM   #7
Ackattack
Ackattack's Avatar
Stock 00 Trans Am fuel tank.....got it with the fuel pump for $50
Ackattack is offline   Reply With Quote
Old 11-06-2008, 06:39 AM   #8
vtblazer
vtblazer's Avatar
I 2nd using FuelCellGuy, he made me a custom fit for my blazer and did an excellent job.
Baffles, in-tank pump...etc.
vtblazer is offline   Reply With Quote
Old 11-25-2008, 11:22 PM   #9
meathead95
computer illiterate
meathead95's Avatar
anyone have fuelcellguys contact info?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-26-2008, 01:34 AM   #10
danman987123
danman987123's Avatar
i do like ackattacks. stock. cheap. gets job done and its from a t/a and the t/a had an ls1 so they were ment to work together pretty much. i got mine from no limit hot rod. i think i paid 450 for the aluminum tank and like another 2 for the fuel injection system inside. comes with pump, line, and everything just ready to connect. does come with all hardware and everything to just bolt right up. nice fit too and all aluminum looks nice... can someone show me how to upload pictures. it says mine are to large
danman987123 is offline   Reply With Quote
Old 11-26-2008, 06:17 AM   #11
lofly'a
lofly'a's Avatar
i've saved all the info on ackattack's camaro tank install and fender widening, and plan to use both on my build. this is great and economical information for the DIYers like most of us. i don't like to farm anything out if i can help it. great stuff "Ack".
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 11-26-2008, 08:26 AM   #12
JMac11
JMac11's Avatar
Best place to get the bolt in seding units????
JMac11 is offline   Reply With Quote
Old 11-26-2008, 09:27 AM   #13
jkaylor68gmc
jkaylor68gmc's Avatar
Call Tanks and get their universal poly truck tank. It fits between the rear rails and you just have to slide the that last crossmember back. The tank is only $215 and the LS pump is another $215.
So that is $430 for everything! Tell John, Josh at Buckaroo sent you.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 11-26-2008, 10:43 AM   #14
tinlid
All those problems of retro fitting in another tank or building one with baffling and in tank pump are not a problem if you go with a mechanical pump.
See: http://www.racepumps.com/
While a little pricey it sure solves a whole lot of problems.
tinlid is offline   Reply With Quote
