Old 11-25-2002, 04:50 PM   #1
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
Vacuum Advance: Good or Bad?
A shop told me that my vacuum advance wasn't working. I put an Ignitor on a little while ago and would have changed it then if I could have broken the screws loose and didn't need to drive my truck home that night. The vaccum advance can wasn't locked up (I could move the plate the points mounted to and it was still as tight as the new can was).
How do I know if my diaphram is bad? Would it be noticable on the highway? I really can't tell a performance difference on the road because I put a new tranny in right before I changed the ignition. Right now it runs better than it ever did, but I am always looking to improve when I can...(afford it).
Any input on this will be helpful. By the way, how do you rotate that plate to get to those screws?
Thanks,
Ro
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 11-25-2002, 05:53 PM   #2
Long Knight
Anyone???
Long Knight
Old 11-25-2002, 06:39 PM   #3
tom hand
CCRider
tom hand's Avatar
To test the diaphram simply stick the vacuum hose in your mouth and suck on it. If the diaphram is bad it will be like sucking air thru a straw. If it is good the can will move the plate and you will feel a vacuum build up in the hose. Isn't low tech testing wonderful?
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 11-25-2002, 06:43 PM   #4
Long Knight
Thanks for the tip.
Long Knight
Old 11-25-2002, 11:34 PM   #5
Dads72
Need help myself on this.
Engine is a 350 (360) with an after market intake and HEI.
Edelbrock (sp?) carb.
The vacuum advance "clicks" - most noticable when you back off and then accelerate going around corners.
A friend to me to just plug the line. It didn't click, but the gas mileage went way down.
Hooked it back up to a port on the carb, and it would still click - even at idle.
Put the hose on the other port and the clicking went away - but so did the performance.
It's not right. How do i fix it?
Another local guru said that I need to get a vacuum advance for a vehicle that does not have EGR. Does that make sense? And if so, how do I find one?
Dads72 is offline   Reply With Quote
Old 11-25-2002, 11:42 PM   #6
breeh
Recovering 67-72 Addict
breeh's Avatar
I've posted this before but it is good info and I have used it successfully.....
Now, for the rest of us: Vacuum advance.
Ported vacuum advance was, in fact, used by many makers of performance and stock engines in the past. Reason, the fuels were so good that the burn temperatures of the combustion chambers actually lowered as upper rpms were reached, and the added timing from ported was needed to heat the burn properly. In those days, the amount of degrees added in the cannister were fairly large, with some engines having 20+ degrees, but this number was usually not attained, as the total amount of vacuum added by the ported port was lower than that needed to get the vacuum advance to pull all the way in.
Today's pump vended fuels, and their additive packages, or lack thereof, have just the exact opposite of the earlier fuels, they always burn much too hot, even stuff like the Sunoco 280 have this problem. Add vacuum advance into the lace most succeptable to detonation, upper from mid to upper rpm ranges, and you can take detonation to the bank, you're gonna get it.
The only time today that ported timing is beneficial, to a point, is on Exhaust Gas Recirculation designed engines. These engines recirculate partially burned gasses from the exhaust system into the intake tract again to be re-burned and reduce emissions output, and the partially burned fuel needs the added combustion chamber heat to more completely burn the exhaust fuels recirculated.
In today's non-EGR performance engines, stock to performance, we do not require any upper rpm added timing for burn temperature control, in fact, it is detrimental to proper running.
So why use a vacuum cannister at all? Well, there is a simple silver lining to vacuum advance, engines as we are working with like timing at idle in the 18 to 24 degree range, but this isn't all that easy to do with some parts packages. How do we do this? Well, first, we need to think of the vacuum advance as not that, but an idle timing supplement to the initial timing.
As we now know, the idle timing can now be raised to a decent level at idle, to help with a stable idle, pull against a bigger than normal cam, pull against a converter and help cool the engine better from more complete idle fuel control. There is a catch, though, too many degrees of supplemental idle timing can be very counter-productive.
If we use the 24 degree figure, we can do things like set the initial timing at, say, 14 degrees, starts easily, then add the 10 extra with the cannister. OK, how do we get the 10 crankshaft degrees into the 20 degree cannister? We use either a Crane scroll plate to stop the advance pin that conects the diaphragm to the point/pickup plate to restrict plate movement down to the number of degrees we wish different from the static initial timing and the total idle timing.
OK, now that we have the number of degrees restricted, do we want to be able to change the vacuum level the canister comes in goes out with? Yes. We do this in two different ways, we look at the information of the stock cannister pull rate, and select the proper one for our vacuum levels, or we add the adjustable cannister from Crane, with the scroll plate that comes with it. Adjust away, you will find the correct amount of added timing for idle to make your engine run correctly.
Well, doesn't the idle added vacuum timing stay in the system when the gas pedal is hit? No, actually. It is immediately dropped as the off-idle vacuum goes away, and the centrifugal advance acts as usual . Only 180 on this is an engine that has no idle vacuum from a realy radical cam duration, and then, the vacuum actually rises after the engine is brought off idle. We just wouldn't use any kind of vacuum advance on an engine this radical anyway. Static idle timing would also be jumped up to 18 or so with the redical engine anyway, to try to stabilize the idle quality. Once again, adding initial timing helps the idle, just depends what you have available to help.
All HEI distributors manufactured for GM vehicles as production ignitions have way too much advance, mechanical degrees and vacuum degrees, and usually cause mucho problems in our performance and stock engines until they are set up correctly, and have full intake manifold vacuum sourced.
99 percent of all vacuum advances have way too many degrees of timing available and need to have the total number reduced to work with full manifold vacuum, as the manifold vacuum will pull all the degrees available into the cannister, not like the partial vacuum pull available with ported vacuum sources does at rpms.
Now, to dispell some myths about dyno tests and ported vacuum advance. Dynos always use more jetting to keep the chamber, engine and water temps cooled off, and ported timing just counteracts the rich mixtures of the rich jetting meeded for the dyno. In all the experiences I have had with crate and built performance engines, ported vacuum advance has been simply not productive, no matter what the engine did on the dyno.
If you are forced to use ported vacuum for your supplemental timing surce, then the curve and initial are not correct, and/or the total amount of vacuum supplemental timing is too large foruse as an idle supplemet from full intake manifold vacuum.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 11-26-2002, 12:21 AM   #7
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
Ease up man, my brain is hurting! good summary though.
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 11-26-2002, 12:58 AM   #8
bigjimzlll
bigjimzlll's Avatar
breeh...nice job..there arn't to many of us that share that belief it seams..I didn't get it at first, but after struggling with it for a while I finally figured it out..what I like about the adjustable vacuum is that you can tune for your own engine needs..my engine like 12 deg. initial with 14 deg. vacuum and total in at 2800 around 35 degrees.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
