![]() Join Date: Jul 2008
heater core went out
i popped the hood today to tighten up myexhaust manifold bolts, and i noticed that the heater core was dripping, then anti freeze started pouring out. so i've got to get a new one. what all will i have to do to get it out?
Re: heater core went out
Yikes!!! Have fun.
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 11-05-2008 at 09:49 PM. |
Dave's not here, man
When I did mine I dropped the fender well out of the way. I didn't take it all the way out, just took the bolts out to drop it down a bit. Seems like I took the pass. side hinge loose too, but I can't remember. As stated above, one of these guys will know it 100%. It wasn't too much of a skank; just takes some time.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
its all about the +6 inches
the fenderwell and hinge are the hard part. Then you just remove the bolts holding the heater box onto the firewall, there's a cable that can be a total bear to remove.
If it is a real nice truck, you'll wanna get a heater box gasket and blower motor gasket too. |
all right i will give it a try, thanks for the help.
Resident Curmudgeon
![]() Join Date: Dec 1999
You mentioned under the hood so we are all assuming its a non-AC truck. If A/C, your heater core is on the inside of the cab, and removal does not require messing with the fender well.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Here is an old step by step how to post by jewels:
http://67-72chevytrucks.com/vboard/s...ht=heater+core
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
I am a Referee of life.
You will want to reseal the heater box to the firewall.the removal of the cable is easy if you look under the dash you will see a small plastic plug with the cable run through it.Pop the plug out with a small screwdriver and you can get a finger in there and lift the cable off the pin it fits on.Reassembly is the same.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
interesting... I never thought of doin the cable from inside
That's great to know - I'm gonna have to do mine soon, and that will probably save me a little time thanks!
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
all righty i am going down to baxters today to get the heater core today sometime and am going to put it in tommorow. thanks for the help!
Actually I can't take credit for that one LHM.I read it in a post on here.I don't remember where though.
#13 |
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
I never drop the wheel well, the stupid clip nuts always snap, and I HATE fighting them. It's been a long time since doing one, but somehow I manage to get the bottom housing bolts with a 1/4" drive u joint on a long extension.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
#14 |
well i got the new one in and out. it all went smoothly, thanks to your guys advice!
