Old 11-05-2008, 11:20 PM   #1
GlennBrittain
2.5/4 ECE drop exhaust question
With the ECE 2.5/4 drop kit will I have clearance to run my exhaust under the truck or do I need to run it through the frame. I do not want to go through unless it is really necessary. I do not want to drag my exhaust every time I go over a speed bump or railroad track either.
GlennBrittain is offline   Reply With Quote
Old 11-06-2008, 12:04 AM   #2
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: 2.5/4 ECE drop exhaust question
I have asked the same question. You would probably have better luck in the suspension section.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 11-06-2008, 09:21 AM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I don't believe that a 2.5/4 drop would be low enough to cause to many serious issues.... your best option would be to call out to ECE and speak with Stan or any of the other guys there. They are filled with a ton of knowledge on the 67-72 trucks.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-06-2008, 09:38 AM   #4
John Fabris
TOTY 2006
John Fabris's Avatar
I am running thier 4/6 drop, and I don't have my exhaust running through the frame. I did use sanderson shorties, and have an H pipe, and exits at a 45 behind the rear tires....
I bottom out on my front a-arms but I have yet to hit the exhaust..
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 11-06-2008, 09:39 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Hey John.... do you have any pics of your exhaust setup?
-Nate
Old 11-06-2008, 10:40 AM   #6
whatnow123
whatnow123's Avatar
You'll be fine. I have a 4/6 drop with an X pipe and haven't dragged it yet.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 11-06-2008, 01:07 PM   #7
GlennBrittain
Thanks all for the info. I did call ECE this morning. I was also advised to use short headers and tuck the pipes up tight and there would be no problems with clearance. I also asked about shock relocaters. ECE said that the truck would run down the road just fine but the ride would be degraded. I plan to order the relocaters today. I did not want to run my pipes through the frame since I would have to come out the sides anyway or go under the rear axle tubes due to my FUELCELLGUY rear tank.
I am trying to get everything off my frame that will not be used and all holes required drilled before powercoating. I will post another trhread on that issue.
Old 11-06-2008, 01:29 PM   #8
race-n-jason
-Praise the Lowered-
race-n-jason's Avatar
Currently I have a 3/5 spring drop using shorty headers and tucked tight to the frame. Here are a few pics to give you an idea of clearance...
JEG
Race-N-Jason
('71 Chevy C-10 LWB 454/TH350)
('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual)
race-n-jason is offline   Reply With Quote
Old 11-06-2008, 01:36 PM   #9
gangforward
Hootis is as Hootis does...
gangforward's Avatar
Here's a shot of mine - I used Hedman Long Tube headers for better performance, and I like having the headers somewhat visible... I have the 2x4 inch drop from early classic...
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires
1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires
1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires
gangforward is offline   Reply With Quote
Old 11-06-2008, 02:22 PM   #10
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
This is the way I use to have it on my 68. The only time it ever hit was when I took a speed bump waaay too fast.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-06-2008, 02:25 PM   #11
GlennBrittain
Thanks for the pics, they always help.
Old 11-06-2008, 03:33 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Glad to hear that ECE was able to help you out. And that's why I'm ordering a ton of parts from them... excellent customer service!
-Nate
Old 11-06-2008, 04:44 PM   #13
chevguy7
chevguy7's Avatar
You will be fine with a 2.5/4" drop and the exhaust not being tucked. ECE is great!
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs
http://67-72chevytrucks.com/vboard/s...d.php?t=272458
2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds
chevguy7 is offline   Reply With Quote
