engine question
Ok...I think i'm kinda leaning toward building the inline, however i'm still having some trouble figuring out which head I need to get...if someone has pictures or can point me to an ebay auction, etc of one, that would be awesome...second, before I can do any of that, I need to figure out what's going on with my engine...I'm about to take it in to get looked at, but it would be nice to get some ideas here...it runs fine, idles fine, it just makes a loud clacking noise and smokes...what could this be??
Also, will a TH350 bolt up to my engine without any modifications? Thanks guys |
Re: engine question
A TH350 bolts up assuming your flex plate has holes that match the torque converter. If you did not have a TH350 or 700R4 you will need to rig a kickdown cable.
Look about 3-4 pages down for a thread 'where are all the 6 bangers?' started by Manimal. On Page 2 there are some good shots of non-integral head engines, basically showing where the intake can be unbolted from the head. http://www.inliners.org/tech/heads/headindex.htm has a partial list of head castings. Avoid the nova siamesed exhaust ports, and watch your compression ratio. Occasionally heads show up on ebay but shipping will kill you. I find an l6 a month on craigslist.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors Last edited by D13; 11-06-2008 at 07:21 AM. |
Re: engine question
Re: engine question
i'm thinking it's for the wrong engine, i just saw the casting number..thinking it may be for a 454...i don't know, i'm new to the chevy scene.
Re: engine question
use the search (chev*, GMC) (250, 230, 292) for a starter, then look at what you don't like and add - strings.
And that is a V8 head.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
![]() Join Date: Oct 2006
Re: engine question
Go to your local wrecking yards and look for a head froma 194. A 230/250/292 head will also work. A 194 will raise your compression ratio,but shrouds the valves. Are you building a 250? 292?....more info please.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Re: engine question
it's a 250...i've got an appointment monday to get my truck looked at so hopefully i'll have more info as to junk it or fix it (the engine that is) so we shall see.
Re: engine question
for the 250 you can use 307 flat top pistons(cast are fine). Take a look at webrodder.com There is someone on there makes cams just for the inline 6's. Good Luck.
-Lance
