Old 11-06-2008, 03:04 AM   #1
nuke1
nuke1's Avatar
Aftermarket disc brake kit (track width)
hey guys, i have heard a few rumors that if you install cpp's or ece's disc brake kit up font that it widens the track with of our trucks by 1.5 inches per side, if this is the case i am gonna narrow my crossmember and frame to accomodate for this, have her torn to the frame at the moment, just have not installed the kit yet, cpp 6 lug disc. Anyone Have experience with this?
thanx guys
James
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 11-06-2008, 06:32 AM   #2
HomerJ
HomerJ's Avatar
Re: Aftermarket disc brake kit (track width)
I haven't used those kits, but I pieced mine together with salvage yard parts. It does widen the front footprint.
I'm considering replacing the rear end with one from a 71 or 72, which widens the rear footprint by about the same amount. The only problem there is that the axles are 5-lug on those years.
HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73
67 Chevelle SS Clone 454/TH400/3.73
HomerJ is offline   Reply With Quote
Old 11-06-2008, 08:15 AM   #3
cparman
sharp as a marble
All of the Master power brake kits we have installed will usually widen track width about 1/2 inch
cparman is offline   Reply With Quote
Old 11-21-2008, 02:50 PM   #4
67cheby
67cheby
67cheby's Avatar
i have installed this on my truck 6 lug i dont know how much it widened mine but it is quite a bit and i dont want to cut my crossmember down, i would be happy to sell you my spindles and brakes, it has never been driven
67cheby is offline   Reply With Quote
Old 11-21-2008, 03:04 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
ECE and CPP kits widen the front track by 3/4 inch per side for a total gain of 1.5 inches total.
This makes the front the same width as stock (disc brake) 71-87 trucks.
I've never felt the need to narrow anything with these kits installed, even running super wide tires on all corners.
Old 11-21-2008, 07:34 PM   #6
nuke1
nuke1's Avatar
thanks for the help guys, i now have to decide what i want to do
James
1968 GMC "HAVOC"
1986 GMC "Frank"
