Starter issues...
So i built a stroker for my truck, and 2 months later i'm on my 4th starter and 2nd flexplate.. :/
the starter/flexplate clearance is good, but then i go to start it and the starter chirps and the flexplate turn backwards a bit, then i check the clearance again and it's moved, i dont know if it's the motor detonating because the timing is too far advanced, or if it just moves the starter on the compression stroke, and the compression is kicking the flexplate back... i figured i'd look into the timing option, and when the motor is running smoothest, it's gotta be like 40 or so degrees advanced... if i take it down to ten it runs like crap... so i'm thinking it's a timing issue, but i'm getting really fed up with this, because i've got a few more go fast parts i cant play with till i fix my starter ![]() any suggestions? i'm about to drop the 307 back in, help me! lol, if anyone actually reads all that, thanks ![]() |
![]() Join Date: Sep 2005
Re: Starter issues...
timeing is your culprit. are you setting the timing with the vacuum advance unpluged? 40 is way to high i think
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
yeah, i've got the advance unhooked, and 40 is ridiculous... could it be that i put the timing chain on a tooth off or something? so the spark's gotta be offset to make up for the cam? i wouldn't think so, because it seems to run good, but i just don't know... this is killin me... lol
thats what i would guess and look for
