Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-07-2008, 01:40 AM   #1
LuckyHenriksen
LuckyHenriksen's Avatar
Tunnel Ram
Any one on here ever ran a tunnel ram small block in one of these trucks? If you can get it tuned right, does it work well with the weight and all?
And how about hood clearance- would one fit under a stock hood?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 11-08-2008, 11:52 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Tunnel Ram
I've ran tunnelrams onthe street (in a light bucket) and on the track. Even did one with a pair of 3310's trying to get street manners, Do yourself a favor,, the 'right' single carb and you will be MUCH happier on the street.
You may think you want this
But trust me,, it really only belongs here
and even then,, I'm running 0.8 seconds quicker with the new combination and a single dominator
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 11-08-2008, 01:15 PM   #3
LuckyHenriksen
Re: Tunnel Ram
Sweet thanks for the advice man. I just think they look awesome stickin out of the hood
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 11-08-2008, 02:37 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
Re: Tunnel Ram
I know someone that ran dual Edelbrock 1406's with a tunnel ram on a 882 headed 350 with slightly higher compression and a large cam. Thats 1200 CFM worth of carb on a 350. It actually did alright. I have a feeling that with the weighted air valve secondary carbs, the secondaries NEVER opened which is why it wasn't so bad. There's no way a 350 of that caliber can pull enough air through those carbs to pull the secondaries open. Had he run true mechanical secondary carbs, it probably would have just bogged. Also, the 882 heads probably kept air velocity in check with the tiny runners and small valves.
Would this motor have made better power with a Performer RPM Air Gap dual plane and just a single 650 carb ? I'd be willing to be it would have.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-19-2008, 11:43 PM   #5
scotts62
One day...
scotts62's Avatar
Re: Tunnel Ram
This is what i had in highschool, yes the cops loved me.....
sorry kinda a bad pic though
Two 450 cfm machanical secondary carbs, Holley dominator intake (dont use this intake though rpm range was way high and intake never hit torque curve, i put a weiand on after and it helped) 305h comp cam, just 882 heads studed and guide plated and just mild pocket ported, block bored .030 over and it ran very good!
Scott
93 crew cab build
Project 62
Old 12-05-2008, 02:37 PM   #6
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Tunnel Ram
Whatcha power plant now in your 62 now Scott? I was thinking of putting a Tunnel Ram kit on my truck from Summit Racing. They a kit on sale for $550 +/- a few dollars several years ago. I have enough clerance for it! Ha ha
http://store.summitracing.com/egnsea...Ns=&rsview=sku
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 12-05-2008, 08:00 PM   #7
scotts62
One day...
scotts62's Avatar
Re: Tunnel Ram
Im going tuned port on mine this go around, it ran really good but dont want to mess with the tunning all the time on a cruiser.
A friend of mine had that exact setup in the pic in a 68 elcamino, 0.30 over with a 292 comp cam i think its right at 500 lift and that thing ran excellent! i wished i had that intake on it back then beacuse the power band was right wherei needed it to be with my setup... but oh well i paid hardly anything for the intake i had
I think that setup is around $700 or so now..
Scott
93 crew cab build
Project 62
Old 12-05-2008, 08:57 PM   #8
1Bad62Pro/Street
Yep! That's about the cheapest kit I have seen. I wished I went ahead about that kit from Summit Racing 6 years ago for $500. My engine is built mild due to the first gas hike! She's pushin only 400 horses now, with a dual pattern cam and peanut heads. I need to put a Detroit locker in my rear and change gears to a 4.10 or 4.56 like my dad has in his rambler. Anyhoot, you got any pics of your truck?
Old 12-05-2008, 11:17 PM   #9
scotts62
One day...
scotts62's Avatar
Re: Tunnel Ram
Yeah actually was going to post up a build thread tomorrow sometime, title will be project 62
Later
Scott
93 crew cab build
Project 62
Old 12-06-2008, 02:52 AM   #10
LuckyHenriksen
Re: Tunnel Ram
Those motors look sweet man. Your putting tuned port on? As in TPI?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-06-2008, 03:02 AM   #11
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: Tunnel Ram
Old mans big block car
On his 306 (327 bored 30 destroked with a 283 crank)
Sits in his 57. Take in mind all these pictures are circa 1975ish, heres a pic of where they lay now
still as they ran, excluding the 57 threw a rod around 1977, but everything's still there he just never got around to rebuilding it.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 12-06-2008, 03:10 AM   #12
LuckyHenriksen
Re: Tunnel Ram
Wow that is a treasure trove! What are the plans? Just enjoy all the history? Or rebuild some of the cars and race them again?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-06-2008, 03:28 AM   #13
Walts_restoration
Re: Tunnel Ram
Hes still around, sitting at the young age of 62, and doesn't wanna do anything with them. Right now we have 150+ cars, and he mainly toys on original unmolested cars, usually meaning old farm trucks and field finds.
I hope one day to get his cars back out, at least his 57, because it was a world record holder, or his blue 68, record holder too, in total he held 3 during his career.
Right now im just focusing on getting my projects done, and enjoying being an 18 year old male, even though old man wont help me finish any of my toys.
Old 12-06-2008, 05:21 AM   #14
1Bad62Pro/Street
Re: Tunnel Ram
Same here bud. Gotta post some parts for sale too.
Later
Old 12-06-2008, 01:23 PM   #15
LuckyHenriksen
Re: Tunnel Ram
Thats awesome. I would love to just open up the barn door and see the stash. Cool cars, and even cooler that they are part of your families history.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-06-2008, 01:55 PM   #16
scotts62
One day...
scotts62's Avatar
Re: Tunnel Ram
Yea, Putting tuned port on truck in my avitar, already sold tunnels ram.
Scott
93 crew cab build
Project 62
