born to lose
Door latch problems
Iam having a hard time getting my door to shut tight. I have tried taken out and redoing the shims but nothing has worked, Im wondering if the latch just needs to be replaced. Any info would be greatly apperciated.
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 ![]() '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 ![]() Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
Re: Door latch problems
Sorry...I needed to jump on the thread, Im having the same issue.
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
Active Member
![]() Join Date: Jul 2007
Not sure which shims you are referring to, but I adjusted mine by loosening the door bracket and tapping in until I got it to shut right.
Be aware that if you have a worn or torn rubber door seal it will affect the way it shuts. I had to readjust mine when I bought new push on seals from GMC Pauls. |
The Older Generation
The striker (pictured above) could also be in "too far" and only letting the door close to the safety catch before it contacts the rubber seal.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-07-2008 at 02:22 PM. |
#5 | |
born to lose
My fix to this problem was that i instaled bearclaw latches
Hollister Road Co.
I replaced the rubber bumpers and the latch to fix the problem.
