11-07-2008, 01:08 PM | #1 |
Auto tranny gurus I need help
ok i have an 87 crew cab dually with a 454 big block and th400 trans.
i have a problem with the tranny slippin i droped the pan and found a bunch of metal dust. no chunks. i changed the filter and put new fluid and it was working good again. i thought that it was slipping cause the filter/pick up tube had droped out of its seat cause i found it laying in the pan. now it is slipping again, fluid is toped off. its slipping so bad the truck wont move. then i shut the truck off and wait 30 seconds and it will go for a couple blocks. feels like the fluid pressure is low, normally when i put the truck in gear i get a strong kick even at idle. now no kick when i put it in gear. is there any external adjustments or is it time to look for a tranny. if i need to replace it i would like to know what year trannys would be compatible. i need to get the truck running again as cheap as possible. thank in advance guys. |
11-08-2008, 01:20 AM | #2 |
Happy to be here
Re: Auto tranny gurus I need help
Anyone?
11-08-2008, 07:32 AM | #3 |
dang its hot
you need a rebuild. What happens is the clutch material in the dirty fluid acts as friction material. When you change fluid you wash all that "help" away. Flushing a transmission as preventative matenence works but flushing a problem tranny usually kills it.
11-08-2008, 03:38 PM | #4 |
hey thanks for the reply, heres an update: i droped the pan this morning and found lots of little chunks this time, what was happening is the little shavings were cloging up the filter/pickup so when i stoped and turned if off they would drain down and i could drive a little further till it cloged again.
i changed the filter and put some fresh atf and drove it strait to the tranny shop, im getting a rebuilt 400 and bigger cooler. i need the truck to be dependible for towing the car trailer. i was interested in a tranny with overdrive but 700r4 is not stout enough for my aplication, so i would like to add the gearvenders overdrive unit later on. |
11-08-2008, 05:48 PM | #5 |
dang its hot
cool!
