Old 11-25-2002, 08:53 PM   #1
71Blazer
Goodbye Darlin'
71Blazer's Avatar
Desktop Dyno help...
I know this is an engine/drivetrain question but only one response over there (thanks messed up c-10).
Could someone with Desktop Dyno crunch these numbers for me? It's not fast but there is torque a-plenty!
Misc:
400 SB
.060 over (413ci)
Headers (1.5in diam.)
Flowmaster mufflers (40 series?)
TPI
Heads (#3998993):
Flow 150.8 int/ 91.1 exh
Diam. 2.02 int/ 1.60 exh
75cc chamber
Induction:
52mm Throttlebody flows 790CFM
Cam (Comp Cams HE268):
Dur. @ .050 218 (268 advertised lift)
Lift .454
1.52 lift roller rockers
Pistons:
dished .060 over (4.185 bore)
C/R 8.5:1 (?)
Am I missing anything?.. Thanks!
1971 Blazer CST SOLD!
71Blazer is offline   Reply With Quote
Old 11-25-2002, 09:04 PM   #2
bigjimzlll
bigjimzlll's Avatar
I used 882 heads with 8.5-1 C/R..260hp @4000 and 400ftlbs of torque @2500 rpm..the C/R is way low for power and the tpi is to small....
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 11-25-2002, 09:45 PM   #3
71Blazer
Goodbye Darlin'
71Blazer's Avatar
Thanks, did the program give ideal numbers for the TPI and C/R?
Old 11-25-2002, 09:51 PM   #4
bigjimzlll
bigjimzlll's Avatar
no it doesent have that function..but the 400 I had on file had 10-1 CR and a 900 cfm tpi..and the hp was around 375 and torque at 440......
Anderson,CA
Old 11-26-2002, 08:52 PM   #5
71Blazer
Goodbye Darlin'
71Blazer's Avatar
Thanks for the help, with compression at 10:1 I would need to run higher octane gas... I wonder if bumping the C/R up to 9 or even 9.5:1 would make much difference and still allow me to use the lower test gas? Anyway it's good to have a general idea of the throttle body this engine can handle...
Looks like a Desktop Dyno purchase is in my near future
Old 11-27-2002, 12:43 AM   #6
Johns70
Johns70's Avatar
where is coupeville?
in relationship to larger towns.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 11-27-2002, 05:23 AM   #7
Project1970
14.1 @ 96MPH
Project1970's Avatar
Just for a compression ratio comparison...my current setup with Vortec heads and an original flat-top bottomend gives me 10:1 compression or so (possibly as high as 10.2:1). DD2K says it's good for about 250hp/250 lb/ft. Dropping it to 9.0:1 makes it 235/238 at the same RPMs.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
