Old 11-07-2008, 07:25 PM   #1
1971c20
1971c20's Avatar
Can anyone help me?
So just recently my truck is makeing the awful noise coming from what sounds like the carrier bareing, or the rear end. it only makes the noise fro 0-35 and when im taking a right hand turn. the noise sounds like if you took a piece of sheet metal and bend it back and forth with your hands, its that bang type noise. also when i put it in reverse it goes ping and sounds like something is scrapeing whie i back up??? Please help this is my daily driver and i have no idea what it could be. Thanks for any advice.
1971c20 is offline   Reply With Quote
Old 11-07-2008, 07:58 PM   #2
joe b
Red face Re: Can anyone help me?
I think you need to get under it and check the u joints and the carrier bearing
joe b is offline   Reply With Quote
Old 11-07-2008, 08:03 PM   #3
1971c20
1971c20's Avatar
Ya that is what i was thinking, but i did not think that it would make that kind of noise but i will do that.
Old 11-07-2008, 08:11 PM   #4
Willys47
Willys47's Avatar
I have heard the ping when the ujoints are starting to go bad and if you leave it you could fine that the driveshaft could leave you.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 11-07-2008, 09:58 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you don't know what you are looking for, you can pull the shafts out and run them to a drive shaft shop. They can install the parts correctly, install the carrier bearing correctly (don't beat on the shaft with a hammer, it spins just as fast as your crankshaft, and you wouldn't DREAM of doing that) Plus, they'll spin it and ballance it if needed.
