Old 11-07-2008, 07:28 PM   #1
truckdude239
truckdude239's Avatar
man whats wrong with me?
i drove my truck to work for the first time in 2 years truck has only had 20 mile put on it in 2 years. and man i couldn't drive the thing to save my life i stalle dit out like 4 time on the hill and i drive a 5 speed escort everyday guess i need to drive it more and get use to it
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-07-2008, 10:08 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: man whats wrong with me?
shame on you for getting un-used to it.
Old 11-07-2008, 10:21 PM   #3
truckdude239
i dont driv eit much becuase the needle sticks in the carb and it randomly floods i'm saving for a new carb
David fuller
2000 Tahoe 5.3l 378
Old 11-07-2008, 11:05 PM   #4
Longhorn Man
I've had good luck just cleaning them up.
Now, unless it's an AFB, I don't take them apart. I've cracked open too many carbs, only to wipe the parts off the table into the trash can when i can't figure them out.
HOWEVER... I'll remove the carb, drain them by turning them till the fuel stops pouring, then fill it up with carb cleaner. Then start scrubbing the outside with more carb spray and a toothbrush swiped from the ex's bathroom.
Rinse it with clean carb spray, drain some of the stuff out, install, and fire up.
Seems lame as heck.... but it works on a lotta semi-dirty carbs.
Old 11-07-2008, 11:53 PM   #5
truckdude239
carb only has 20 miles on it also it was a remaned carb and the warranty is out on it they where going to warranty it but there was no more available at there warehouse so i am looking at http://www.carburetorexchange.com/pl...n_model_id=291
David fuller
2000 Tahoe 5.3l 378
Old 11-08-2008, 08:59 AM   #6
I`d clean it.Why else would it be sticking?Gas sucks these days.It can`t sit in a carb more than a few monthes without running without plugging up the carb,causing need for a teardown.
Old 11-08-2008, 10:18 AM   #7
69long"n"low
69long"n"low's Avatar
Try a few weeks, you should see some of the boat motors i see. You leave them sit for more then a month and you start having problems
- Josh
Im not white trash, I'm one step above that..... more like white clutter
69long"n"low is offline   Reply With Quote
Old 11-08-2008, 10:34 AM   #8
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
My suggestion is If you dont run it much, fill the tank with high test and STP gas treatment and run it until you flush out all the low octane stuff. High test has the best stabilizers available in it. The gas companies had to put them in, of else pump out the stuff every 3 months at a gas station. I have always has great luck with this, as I do not winterize by draining any of my equipment.
Also, try to keep the cab shaded from the direct sun or keep windows open so it doesnt get real hot in the cab. That heat in the cab will rapidly break down gas making it a mess for your fuel system. It also weakens the octane rating of the fuel.
Just my experience.
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
