hood brace repair
I have 2 hoods for my 1950 and both have rust thru on the brace that the hinge bolts to on one side. is there a repair piece for this?
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
Re: hood brace repair
never heard of one - do a little surfing, but you will probably have to fab something up -
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
That area rots out because the brace is a hat section channel and traps all the dust/dirt at the lowest point. Of course it absorbs and hold moisture so this rots the brace out from the inside. It is a fairly easy fix with the hood off the truck. Remove all the rotted material, treat the inside area with a rust converter and prime/coat the heck out of it once that drys. Then weld in a replacement metal piece and grind to taste. Just watch the heat build up as it will warp the hood skin.
#4 | |
