11-08-2008, 09:44 AM | #1 |
what are the carb adjustments for 4barrel roch. quadrajet
What are the carb adjustments for the drivers side screw and he passengers side screw for a rochester quadjrajet 4 barrel carb on 350 v8
11-09-2008, 01:07 AM | #2 |
Re: what are the carb adjustments for 4barrel roch. quadrajet
Not enough info. But if you mean. You had it apart, and put it back together & won't start. Then screw them both in till the needle bottoms out. Don't use force. Back them both off about 2 turns. That should get it running. The final adj. has to be done after it's warmed up, and gets into a little more detail.
