Old 11-08-2008, 10:00 AM   #1
ericpost
ericpost's Avatar
14bff lube question
This is embarrassing but..
Does the gear oil lube the wheel bearings in the hubs on a 14bff? When I pulled mine apart it seems like the answer is yes but when I look at the fill plug which seems to be below the axle tubes I think no.
72 GMC Jimmy, 350, sm465 np205 (getting a face lift)
64 Nova SS, 327 SC & gassed, TH350. (blowed it up)
84 HD FX frame,80 FL tins, evo with 85hp/90tq (wifes bike)
96 HD FatBoy evo with 102hp/100tq (mine!)
KEEP NOTHING STOCK!
ericpost is offline   Reply With Quote
Old 11-08-2008, 10:19 AM   #2
snj8198
snj8198's Avatar
Re: 14bff lube question
yup. filler up.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 11-08-2008, 11:27 AM   #3
kwmech
If the diff is dry it will take a full gallon to fill 'er up
kwmech is online now   Reply With Quote
Old 11-08-2008, 04:22 PM   #4
va_tlc
va_tlc's Avatar
fill it up and drive it on a hill or jack it up on each side to get oil out there before ya drive.
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 11-10-2008, 05:26 AM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yep get it filled up!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-10-2008, 09:53 AM   #6
FormerMember
Are you looking at the fill plug on the side of the axle housing or the drain plug in the housing cover?
FormerMember is offline   Reply With Quote
Old 11-12-2008, 09:57 PM   #7
ericpost
ericpost's Avatar
Looking at the plug axle housing.
KEEP NOTHING STOCK!
Old 11-12-2008, 11:09 PM   #8
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
The lube in the housing does lube the wheel bearings but if the hubs and bearing are dry when you put it back together you will need to fill it and jack each side up so the bearings don't start out dry or do what i do.Put some wheel bearing grease around the races.... not real heavy,just enough the the bearings don't start out dry.
powerdriver 1958 is offline   Reply With Quote
