Tire Size?
My questions are, what size tires are stock on the 2wds? P235/75/15s or LT235/75/15s? And what is the diameter of the stock size tires?
I am going to need new tires for my daily soon, and I am looking at putting 20s on one of my project trucks and dont want to throw off the speedometers. |
Re: Tire Size?
There is a difference between passenger tires (P-metric) and light truck tires (LT) but they can be interchanged if you follow the conversion chart. The sizes are close, but it usually takes more air pressure to use them on trucks.
As far as tire size (diameter), that is the beauty of the metric sizing. All of the numbers have a meaning. 235/75/15 breaks down like this: 235, section width in millimeters 75, aspect ratio (height of tire from rim to ground expressed as a percentage of it's width) 15, wheel diameter (must be converted to millimeters) So it works like this: 235mm x .75.........................176.25 (height of tire from rim to ground) x2.......................................352.5 (tire is on both sides of the wheel LOL) + wheel diameter (in mm)........381 total is diameter of tire in mm..733.5 divide by 25.4 to convert to inches 28.87 (28 7/8") Last edited by LONGHAIR; 11-08-2008 at 05:04 PM. Reason: speeling |
Re: Tire Size?
good info longhair,
it amazes me how many car guys don't know how to figure diameter.....
Re: Tire Size?
Thanks for the info, that will help me out alot. I have never seen the formula for figuring out the diameter before. Though I did know what the numbers on the sidewall meant.
Part of the reason I was asking is that the light truck tires on one of my burbs appear to be much bigger than the passenger car tires on my dd burb, both being 235/75s. |
Navy Radioman Veteran
Re: Tire Size?
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
Parts and more parts
Re: Tire Size?
Use this simple calculator for tire sizes and comparisons. http://www.discounttire.com/dtcs/infoTireMath.dos
LASO: this simple formula 235/75/15 tire calculated by 235 X .75 X 2 divided by 25.4 Plus the rim size 15" = 28.8" tire Last edited by piecesparts; 11-08-2008 at 08:04 PM. |
