What is a manual throttle used for??
Okay, looked at a 71 C-10 4X4 this afternoon and it had an optional Manual Throttle knob on the dash. I understand the meaning of it, but what was it used for? Any ideas?
1970 C-10 LWB 1998 Jeep Wrangled TJ 2009 Honda VTX 1300 2013 Buick Enclave |
Re: What is a manual throttle used for??
You can set your idle.Like when you have a pto you want to bring the idle up is one reason.It`s a good question.
PTO is really the only thing I know of, for having it. Though I guess you could use it to bump up the idle speed when jump-starting Furd?
Yeah that what I use mine for on my wrecker . Bump the throttle up, so the winch works faster.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 11-08-2008 at 07:03 PM. |
1. Used to use it as a warm up idle, 2. Cruise down a flat highway. I know its wrong but it worked.
its all about the +6 inches
frequently when workin in a hay field they'll set the throttle a little over idle with the truck in gear, and let it idle down the field while the driver would actually get out and work with a helper.
Auto pilot if you will |
it also works great for plowing when you have the old hydraulic plows. it will get the idle up so the plow will lift faster. also it helps warm the truck up quicker in the winter.
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
![]() Join Date: Aug 2008
I know alot of the guys that rock crawl with their jeeps in Moab use a hand throttle. They use it for one less function to have to control going up some of the obstacles. I don't have one on my jeep, but I didn't go crawling to the extent that alot of them did.
Nick "Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson 1968, GMC, SWB, Project 1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components. 1972, C/10, LWB, 350 vortec, th350 |
To The Levy
It's for the grandchild , sitt'n in the center of the seat to jack with grandpa driving in the fog, the lil guy pulls out and gives grandpa a heart atack, and now he is proud owner of that truck......
I am a Referee of life.
What LHM said.My uncle useed one for years on a cattle ranch in SD.The old ranch Jeep had one and he would plow a circular furrow around the fields.Then early in the AM at feeding time he would pull the front tire into the furrow and set the manual throttle.then he stepped out onto the running board and into the bed to pour out bags of feed.
He also used it to warm the truck up and as a helper for the plow.That is one Jeep I know of that got worked every day of it's life.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Feb 2007
yup. throttle up a bit in granny gear and point the rig straight down a hay row. we could toss bales on the back till the end of the row, get the truck turned around and start down the next. use it for winching and running an air compressor if its peak output is off idle. -steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
I know Ive done that just to play,but wasn`t going to tell
![]() Also in farming,you can syncrho with machinery.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-09-2008 at 10:14 AM. |
