Old 11-08-2008, 07:12 PM   #1
Fastfun
Fastfun's Avatar
Save the Rosette
I was able to take off my vin tag and save the rosette rivets that hold the tag on. I used a die grinder to grind the back of the rivet flush with the body then I used a small drill to push out the pin. I made a little pin puch out of a small drill bit (there isn't much room to swing a hammer in there) I used a needle nose vise grip to hold on to the punch. I placed tape over the rivet
(that's important if you don't you might not be able to find the rivet). A couple of swings and they pop out.
When you install use 4 rivets to line up the holes and mask around the vin tag. I would use 3M super 77 adhesive spray the vin tag and the body. Then use the rivets that you used to line up the holes to make sure that the holes line up for the rosette rivets. Use super glue to glue the rivets in place
Fastfun is offline   Reply With Quote
Old 11-08-2008, 07:53 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Save the Rosette
A very thin coat of urethane windshield sealer will do the trick, also. It holds like gorilla glue once it sets up.
piecesparts is offline   Reply With Quote
Old 11-08-2008, 09:04 PM   #3
custom72c20
custom72c20's Avatar
they sell rosette rivets new. they're a little pricey but here's the link.
http://restorivets.com/index.php?_a=...od&productId=5
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 11-09-2008, 07:55 PM   #4
otsenre
otsenre's Avatar
Does the gas tank need to be out to get to the back of rivets, I recently drilled out rivets off a 68, they wernt rossette, they appeared to be rounder
otsenre is offline   Reply With Quote
