Old 11-08-2008, 09:09 PM   #1
TeamRinaldi
TeamRinaldi's Avatar
Question High pitched hum
Ok, so I've got a new sound. You all know what I mean, you know every sound and squeak your truck makes. Then one day, there's a new one. Hopefully one of you guys can point me in the right direction. It's coming from somewhere on the front left side. I can hear it sitting in the cab and when I crouch down beside the tire, but when I pop the hood I can't hear it. At first I thought power steering fluid, but that wasn't it. It's a real high squeal, like a mosquito in your ear. Any takers?
TeamRinaldi is offline   Reply With Quote
Old 11-08-2008, 09:16 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: High pitched hum
ok so it happens when the truck is at hi idle or running out of park? or does the truck have to be in gear?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-08-2008, 10:30 PM   #3
TeamRinaldi
It does it all the time. When it first started it would sometimes stop when I stopped, but now it's constant. It doesn't get louder or softer at rpm change though.
Old 11-08-2008, 11:08 PM   #4
old Rusty C10
something loose on/ near the cat or something on the exhaust shield or something like that?
Bob
I hate cancer!!
Old 11-08-2008, 11:12 PM   #5
TeamRinaldi
I don't have a cat, but I didn't think about the shield. If it's rubbing, then that would make sense. I'll check it tomorrow and let you know what I find. Thanks!
Old 11-09-2008, 08:24 AM   #6
grinch4om
dang its hot
grinch4om's Avatar
process of elimination, take off your belts one at a time and listen, also push on body parts in a sensible pattern, that may eliminate or amplify the noise so you can isolate it
grinch4om is offline   Reply With Quote
Old 11-10-2008, 02:34 AM   #7
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I would try that and go from there and see what you can figure out.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-13-2008, 05:14 PM   #8
TeamRinaldi
Well, it's not the heat shield or any body panel so far as I can tell. It seems to be steering related (I think). It doesn't get louder or softer, but when it's in gear I can make it stop sometimes as I turn the wheel from far left to right. Maybe the pump starting to go?
Old 11-13-2008, 06:17 PM   #9
old Rusty C10
it could be the pump.. i was leaning away from the power steering because you said you dont hear it under the hood.... Im wondering if there is a slight glazing or polishing of the pulley which allows some slippage.. sometimes a bearing in the pump will also make an intermintent sound...
Bob
I hate cancer!!
Old 11-13-2008, 10:02 PM   #10
spoon
Registered Penetrator
spoon's Avatar
Does it sound like a "squeal" as apposed to a "hum?" Reason I ask, is my steering is suffering from something like this too. When still and I turn the wheel, it seems like the power steering is having a hard time getting the job done. Everything is fine while driving though.
"Some people wear Superman pajamas. Superman wears Chuck Norris pajamas."
"Chuck Norris is the only person on the planet that can kick you in the back of the face."
"Chuck Norris doesn't 'tea-bag'... he 'potato-sacks.'"
spoon is offline   Reply With Quote
Old 11-13-2008, 11:00 PM   #11
Mike 85
Face your fears
Mike 85's Avatar
Pull the pump belt and start it up. This will rule out the pump for sure.
Outside wierd chance it's a vacume leak on the brake booster or vac line.
Pull the vac line off the manifold and plug the manifold nipple.
If it's OK,then reconnect vac line and pull the booster fitting and stick your thunb over the end.
OK,
It may be the booster diaphram if it comes back.
Crazy I know but I've found more "problems" that the "normal" solutions don't fix go back to the brake booster.
I've fixed more engine issues than you can count after people have been pulling their hair out and done everything from new carbs to valve jobs because the booster was bad and loosing vacume.
I was told once, You have no BALL'S....
I then handed him my spray gun..........
My Junk
Mike 85 is offline   Reply With Quote
Old 11-14-2008, 08:07 AM   #12
TeamRinaldi
Thanks for the ideas, I've definitely got some homework this weekend. I suppose you could call it a squeal, but it's really more of a whine. Honestly you've got to find the humor in describing a sound. It's weirding me out because it's real faint, doesn't do it all the time and I can only hear it on the left side of the truck, predominately on the lower side. The truck's running fine but now that I think about it, I have been getting more road feedback than normal through the wheel while driving. At first I thought it was just rough road (she is 25 after all) but maybe it is the pump. I'll work on it over the weekend at let you know what I find. As always, thanks for the wisdom and advice guys.
Old 11-18-2008, 05:33 AM   #13
TeamRinaldi
Well the weekend has come and gone, wish I knew what to say. The sound's gone, so I should take that as a win, but where it went, I can't say. Oh well, I guess if it ever comes back I'll know where to start looking. Thanks again for the tips and advice guys.
