11-08-2008, 11:04 PM | #1 |
Nothing to see here.....
Picture Request: Factory Tach Harness/Vacuum Tubing
I need a pic of where the factory tach harness col wire goes through the firewall. my 67-72 assembly book shows the coil wire entering the engine bay close to where the oil pressure tubing comes through. however on a search, someone posted the location was to the right of the main harness connection under the master cylinder.
and...... I'd also really like a pic of the factory vacuum gauge tubing in the engine bay. this will probably only be able to come from the big boys (C-40 and above). I know where it connects to the manifold, but I'd like to know where it enters the cab and if it is coiled like the oil pressure. Thanks!!!!!
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
11-09-2008, 10:09 AM | #2 |
Re: Picture Request: Factory Tach Harness/Vacuum Tubing
Here is a pic of the firewall on a 72 with factory tach hole located to the left of the bulkhead connector. Other years could be different.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
11-09-2008, 11:37 AM | #3 | |
Not a bad nut after all..
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
11-09-2008, 02:12 PM | #4 |
^^^I'd like to know that as well. was it rubber tubing or hard line like the oil pressure line. my bet it was hard tubing....
thanks for the pic Jim. I read the thread that you had posted that pic before. thanks for the good info! any other tach or vacuum info out there???
11-09-2008, 02:34 PM | #5 |
70+ ( Old Skool Club )
ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-09-2008, 05:58 PM | #6 |
doug all vac gauge clusters i have taken out have been hard line, i got a 70 1/2 ton that the owner had the dealership install a vac in the cluster it also has the hard lines..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
11-09-2008, 06:08 PM | #7 |
Thanks Jamie!!! I should have pulled an oil pressure line when I was at the salvage yard yesterday. Darn it!
11-09-2008, 08:25 PM | #8 |
the lines for vacs are bigger like brake lines, or they are from what i have seen.. good luck.
11-09-2008, 08:39 PM | #9 |
just an fyi to all.
I drilled the bulkhead in the exact dimple that Jim had pictured above, and it was perfect. the reproduction tach harness (from Classic Parts) fits the location like a glove. the wiring had the correct length and the coil wire was long enough to run up to the bulkhead gutter, over the engine, and back down to the coil. a little non adhesive black tape and it looks completely factory. now on to the vacuum portion of the show......
11-24-2008, 01:28 AM | #10 |
Any updates on the vacuum gauge?
11-24-2008, 09:11 AM | #11 |
installed in the cluster (and it loos killer!), but dealing with a vacuum advance issue right now. as soon as I get my stumbling engine problem figured out, I plan on getting pictures up.
12-10-2008, 09:43 PM | #12 |
I have two ideas for vacuum gauge "plumbing":
Feedback is appreciated.
06-11-2015, 11:54 AM | #13 |
1972 Chevy C10 Custom Deluxe Highlander 1972 Chevy C10 Custom Deluxe Medium Green |
06-11-2015, 03:16 PM | #14 |
I haven't installed mine yet but have all the parts and will use a steel line from the fitting on the engine to inside the cab then use rubber line to connect to gauge.
06-11-2015, 05:56 PM | #15 | |
any pictures would be great.
06-11-2015, 07:47 PM | #16 |
Hi Guys, I dont have a picture but my 70 GMC has the large vacuum gauge in the center of the dash ( between the speedo and gas gauge) and it has a rubber hose that runs through a gray plastic grommet, then to the side of the QJet. hope thes helps. mike
