Old 11-09-2008, 12:25 AM   #1
69step4x4
69step4x4's Avatar
Conversion info please
My brother is converting his 69 bigblock 3/4 ton 2wd to a 4wd. He is using dana60 front 14bolt rear 396 turbo 400 -205. Does he need to change the motor mounts and front crossmember? any info is appreciated.
Thank You
Lowered 2002 PT Cruiser ONLY for mileage.
1969 Stepside 4x4 ( under construction )
69step4x4 is offline   Reply With Quote
Old 11-09-2008, 01:11 AM   #2
Ricks1971
Ricks1971's Avatar
Re: Conversion info please
I think his best bet is to find a good 4X4 frame. I know the frames are different 2wd and 4wd. Does the 3/4 truck have leaf spring rears? I still would look for a good 4X4 frame.
Ricks1971 is offline   Reply With Quote
Old 11-09-2008, 01:19 AM   #3
69step4x4
69step4x4's Avatar
Yes leaf rears and he already has the front done and springs and dana 60 already in place. its just the motor trans and TC . just looks to me that the motor is sitting up a bit.
Old 11-09-2008, 11:43 AM   #4
Ricks1971
Ricks1971's Avatar
A 4X4 engine does sit back abit towards the firewall when you use a 4X4 frame not sure about if you convert a 2wd frame though
