Setting up a 4 link
Hey guys,
I picked up a new 4 link for my truck at the local car show, and was wondering if anyone has set one up properly with a dropmember. Any input would be greatly appreciated, especially geometric stuff! |
#2 | |
Re: Setting up a 4 link
Triangulated, you need the triangular bars to be greater than 30 degree angle to keep it from going side to side, unequal length obviously for top and bottom will create a change in pinion angle throughout the range of travel, which can be good or bad, depending on what you want to use it for. Those are a few things that pop into my mind right now, its midnight and I've studied 6 hours for tests so might have a few more thoughts when I'm awake again haha. |
#3 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I'm almost done with a Morrison Tri-4 bar in a '67.....is there something specific you need to know? What brand is yours? I had to do some fabbing to make it work. I can get you some pics if it will help.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 11-10-2008 at 01:46 AM. |
I think I may be putting more into this then I really need to. I was going to use a 4 link calculator to set up the handling perfectly, but I'm thinking that is no necessary. I.m wondering how far the lower link must be placed from the frame to keep good frame clearance, but not so far out it get near the tire. Any pictures would be greatly appreciated!
Hollister, CA.
![]() Join Date: Sep 2006
Sweet...does this mean the cabs are done..and your working on the chassis !?!?!?
BTW, this should be in the suspension forum.... ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Hey Rob, I had the same questions as you when I was starting to order parts for my 4 link. Heres a good thread in the suspension section.
http://67-72chevytrucks.com/vboard/s...d.php?t=270699 Hope that helps. |
#9 | |
I thought about the suspension forum, but I was hoping for an easy answer.... ![]() Last edited by PrerunnerRob; 11-10-2008 at 10:12 PM. |
Hollister, CA.
I went to the show on Saturday too...was actually a nice turn-out...LOTS of rides there considering the weather looked crappy.
60-66 Nut
Here are a few pics of the tri-4 bar that I did on a '67.
60-66 Nut
And a couple more.....
#13 |
Very nice work!
I just tried out the 4 link calculator I found at pirate4x4.com, and it works perfect. All of the technical data I could ask for, and alot I probably don't need. I think I'm going to use this to set everthing up in theory, and move stuff from there. Sweet!!!!!!! ![]() |
#14 |
I know! I tried to stay away from the FBI booth, but too many good deals to pass up(especially after 2 beers)! 4 link and 4 valves for $300 cash!
#15 |
After looking at the photos...I understand why you are know as Captainfab.
Very nice work. Last edited by LILRED66; 11-10-2008 at 11:52 PM. |
#16 |
ok, one last question. Why mount the lower links inside the frame instead of outside? I would think the truck would be less prone to chassis roll the further the bars are spread apart. Is there an issue of the tire to link clearance?
#17 | ||
60-66 Nut
![]() Yes Dan and Greg's 4 link calculator is pretty sweet Yes it is best to have your arms as far apart as you can for better control. This one was done this way for a couple of reasons 1) this was all a kit that was purchased from Art Morrison, and in order to get everything to fit in the required space that is where they ended up. 2) There just isn't room for the lower bars outside the frame with the tire & wheel size that will be ran.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 11-12-2008 at 01:28 AM. |
#18 | |
Excellent info, thanks for the help!
#19 |
nice work Capt.
is that truck finished? if so how does that setup handle?
#20 | |
60-66 Nut
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 11-12-2008 at 02:27 AM. |
#21 |
60-66 Nut
No problem, Let me know if you need anything else.
#22 |
3DrDwn--the 'burb not the band
cap'n,
I may be wrong here but it was always my understanding on the tri 4-link that the "longer" bars were the uppers and were longer to compensate for being mounted at angles instead of straight like on a parallel 4 bar. It was also always my understanding that it was done that way to keep the pivot points on the frame the same distance from the axle and to minimize pinion change. I see by looking at your pics you went with the short bars up top and have a pretty good distance between your pivot points. I'm not saying right or wrong just curious why you chose that way and what the benefits are? TIA, Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
#23 | |
One day...
Setup looks good ![]() |
#24 | |
60-66 Nut
The '67 that I'm building is for a good customer, and with my limited link suspension experience, I decided to play it safe and just order the kit from Art Morrison. The Tri-4 bar suspension was designed by the engineers at AME and is a proven setup, which is one of the reasons I went with it. The bars come already welded and the kit comes with instructions giving parameters for installation. Here is the kit that I ordered http://artmorrison.com/layout.php?y=...i4bar/&x=index I am by no means saying that this is the best triangulated 4 link for the street, it is just one that is proven and was the 'safe' way for me to go at the time. If it was my own truck I probably would have built one from scratch. Let me know if I can be of any help Josh John
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 11-13-2008 at 01:07 AM. |
#25 | |
60-66 Nut
