Old 11-09-2008, 03:48 PM   #1
Wolf
Rear main seal
Rebuilt my 270 and now the rear main seal is leaking. I'm so f...... pist, I'll have to take it back out agian. Any ideas why this could be leaking after rebuilding. Used a good seal from Fel-Pro.
I thought it would swell up and stop, but after I stop theres a good spot on the ground.
Anyone heard of a rubber seal? Can I use one for this and where can I get one.
Wolf is offline   Reply With Quote
Old 11-09-2008, 04:21 PM   #2
OrrieG
OrrieG's Avatar
Re: Rear main seal
When you did the rebuild did you check the crank seal surface for any wear? Might not be the seal but the crank is worn enough to not properly seal. Just a thought.
OrrieG is offline   Reply With Quote
Old 11-09-2008, 05:05 PM   #3
Wolf
Re: Rear main seal
The crank was grinded and cleaned. All new bearings.
Old 11-09-2008, 05:54 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Rear main seal
On the rear cap you need to put some RTV on the mating surface so it seals up the end of the engine. These old motors will leak around the seal.
I would do an in truck repair. just drop the pan and the rear cap and make sure you seal up the pan ends with RTV as well.
On the cap use just a very thin line of RTV 1/32 or less. You don't want to change the clearence on the bearing.
dwcsr is offline   Reply With Quote
Old 11-11-2008, 09:43 PM   #5
Wolf
Re: Rear main seal
Thank you.
Old 11-11-2008, 10:06 PM   #6
mr48chev
mr48chev's Avatar
Re: Rear main seal
You will probably have to loosen all of the main bolts to let the crank drop just enough to roll the top half of the seal out.
Make sure that the lip on the seal is installed in the correct direction too as I have followed behind someone who didn't and the rig had a big leak.
Old 11-12-2008, 12:08 AM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Rear main seal
Very good point. Its one of the biggest reasons for a leaking seal after a rebuild. I just assumed you used a rope seal but most kits these days use the lip type inserts and not a rope seal.
