rearend ratio on a 1976 C10
I have a 76 step side that originally came with a 350 and 3 speed manual. I just went to check the rearend ratio and after turning the wheel one complete turn, the driveshaft only turned 1.75 times.
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
Re: rearend ratio on a 1976 C10
If you hold one tire still & spin the other, you have to take your number X 2 because of the spider gears.
1.75 X 2 3.50 I think the ratio offered for that year closest to your count was 3.73, so I'd bet your count is actually a "hair over" 1.75 And, welcome to the board!
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
Hey guys I do appreciate your help both worked ! Thanx Ed
pull the cover off (drain oil) look at the numbers on the ring gear... 41:11 is 41 divided by 11 = 3.727272 or 3.73
raplace seal and oil and you have a 100% accurate idea and a serviced rear diff...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 11-09-2008 at 06:55 PM. |
Thanx again we got er solved with your help its a 3:42
That sounds right...my '76 C10 with 350/3 speed came with a 3.42 gear set.
Mike |
I was wondering what mine is, I just didn't want to do that just yet, too many other leaks to fix first.
'71 ![]() '10 Dodge Charger SXT - DD '91 Kasel M101A2 3/4 ton trailer (It has Chevy rims!) |
If you do that you can also pull your axles and put new seals in the end of them, then it snowballs with brakes, bearings and so on...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 11-10-2008 at 06:20 PM. |
