It'll buff out
Weird and Loud vibration please help
Ok my truck has a really loud and annoying vibration when i get my truck at about 2500 rpms and stops at 4000 rpms. Its not my tire balance or alignment cause it does it when it's in park revving it up. I replaced my rear U-joint but not my front so it might be that or Someone said it could be my flywheel.
Anybody else having this? Last edited by allen123; 11-09-2008 at 07:39 PM. |
![]() Join Date: Oct 2005
Re: Weird and Loud vibration please help
Flywheel, bent fan blade, or harmonic balancer
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. ![]() |
Active Member
2nd all the above
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
if you're stopped and it's doing it, it's not the ujoints. If its a flywheel it will sound like a rod knocking. Could be a harmonic balancer.
It'll buff out
alright thanks
I already replaced the harmonic balancer It could be the fan blade cause its pretty roughed up But im not sure if it would make that big of a vibration cause its a pretty rough vibration And its been doing it since i got the truck and my flywheel just started clicking like that yesterday |
its all about the +6 inches
what engine does it have?
check the flywheel for cracks and convertor bolts
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
It'll buff out
Ok thanks
Well took the fan off earlier to see if it was it and its not the fan, So i guess it leaves it to the flywheel my dad is going to be home tomorrow so we'll prob take it off and look at it. |
did this just start? Did it start after changing anything? I had the same problem and did all the same things you did. It was the flywheel. Is it a 400 flywheel? Have you lowered or altered stance and changed pinion angle? Again the big ? is when did it start. Gary
does it shudder at any speed. I bet it is the flywheel, cracked or not a 350 flywheel
![]() Join Date: Sep 2005
that right there tells you it is not a u joint because in park your drive shaft is not spinning
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#13 |
I wish I was a cowboy
![]() Join Date: Apr 2008
I third (or fourth?) the flexplate. They crack, they warp in high temps, the bolts take a huge beating every day. If it's at particular rpm, it's likely not crank/rod/pistons. So you only have balancer/pulleys/fan/flexplate left...
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
#14 |
It'll buff out
It's been doing it since i got the truck in april.
