11-09-2008, 10:51 PM | #1 |
Help Me Make More Power!
I just got my truck running and driving, and I am already tired of the lack of power. Truck has a 350 and a TH400, with 2000 RPM converter and 3:73 gears. So heres the winter plan-
Pull the motor back out (stock 350 with edelbrock performer cam, intake and carb) Pop the pan and put in a better gasket Re-ring New cam (roller rockers etc....) New intake New carb (Blow Through?) Heres where I need expert advice- Picking a cam and intake. I want this to be a fun street motor, with as much power as possible. I love high RPM's, but realize that I need a lot of low end power to get the beast to move. What would be a good cam? Somehting with some thumpy idle preferred.... and how about a new intake? I love the look of the Edelbrock Victors, but are they not practical for street use? What would you recomend? And I am looking for a new carb, I want to eventually put a mild turbo setup on this rig and so a blow-through demon is on the menu. Any help or advice is much appreciated. Last edited by LuckyHenriksen; 11-09-2008 at 10:52 PM. |
11-09-2008, 11:21 PM | #2 |
Resident of Here
Re: Help Me Make More Power!
Call the cam/intake mani/carb company(s) you want to get the cam from and they can help you ALOT with asking you questions ans such.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
11-09-2008, 11:33 PM | #3 |
72 Chevelle Club
If your going to use a turbo/blow through supercharger you will need a cam and intake and carb to work with it . I would start with the turbo set up first and get components that work with it . My 2 cents, Bob
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
11-09-2008, 11:38 PM | #4 |
Is there that much difference between a regular cam and a boosted app. cam?
11-09-2008, 11:43 PM | #5 |
72 Chevelle Club
Yes the lobe centers on boosted motors are usually around 114 or higher , Bob
11-09-2008, 11:47 PM | #6 |
Resident of Here
If you want quick power without having to take the engine out, get a Procharger!
11-10-2008, 12:35 AM | #7 |
Ok, ill ask around. Ill probably go with an N/A 'stick for now
11-10-2008, 12:38 AM | #8 |
DON'T TREAD ON ME
A few things.
1. What kind of heads do you have? 2. Demons are great carbs but only on the exact combo they are designed for. Do not buy a Demon designed for a blower, but run it naturally aspirated till you get a blower and expect to be happy with the results. 3. Some setups do OK on the street with a Victor but torque wins stop light to stop light racing and that's almost always done best with a dual plane intake like the Performer RPM.
Old Yeller Last edited by Old Yeller 1970; 11-10-2008 at 12:38 AM. |
11-10-2008, 12:38 AM | #9 | |
Even if I did I think I would still pull the motor cuz the pan leaks like a beast and I would like to make sure the rings are good before making any horsepower with it. Thanks for your responses guys |
11-10-2008, 12:41 AM | #10 | |
11-10-2008, 01:34 AM | #11 | |
DON'T TREAD ON ME
Speed Demon 650's only work with cams at or above 230@.050". That will give you plenty of thump. (I oughta know.) But that's not compatible with a 2000 stall torque converter and requires a good set of heads to flow that big a cam shaft. You'll want a smaller cam to match your torque converter in which case a Road Demon 625 is probably your more likely choice. I had the RD 625 when the engine still had the stock heads, slightly better than stock cam, Edelbrock Performer intake and headers/dual exhaust and can testify that it was far supperior to the Q-jet with respect to power. I gained quite a bit more off the line torque and top end HP. I think the type of cam the works best with a 2000 stall torque converter (I'm a manual guy so others may need to chip in here) is something like Comp Cam's 268H. IIRC it has 218@.050" on the intake. Can't remember the exhaust right at the moment. And they work great with the RD 625. I think Vortec heads will work with it without extra machining but they have small combustion chambers and will probably increase your compression too much so I'd be cautious about it.
Old Yeller |
11-10-2008, 02:12 AM | #12 |
Wow I need a neighbor with as much wisdom as you
You have some very good advice and I thank you for sharing it. I am really not looking to put alot of money into this motor, I want to go LS- based in the future. Maybe a basic cam upgrade is all I need. I just feel that the engine has so much more to give, it just needs a little help. I will look for a nice street cam and Air Gap intake. I would also like to switch over the HEI ignition, I have an old dizzy that I will rebuild, what else do I need? |
11-10-2008, 09:36 AM | #13 |
DON'T TREAD ON ME
Just keep in mind that the limiting factor in making power on an otherwise stock engine is the heads. My original heads were 441 castings which make good torque. 882 and 462 heads are even better. But other stock heads can really kill a camshaft's ability to make power, so before you sink a lot of money into a new cam you might want to pull your valve covers and see which castings you have.
What carb are you using now?
Old Yeller |
11-10-2008, 09:44 AM | #14 |
I am a Referee of life.
You may want to pull the motor before you spend your money on speed parts.If the engine isn't up to par as far as rings,bearings and valve seal you will probably still be disappointed with it.
As stated above the heads are pretty much the limiting factor.I hear a lot of people touting the vortecs but I really think that the aluminum aftermarket is a better deal.Even budget heads are going to be much better than vortecs and for a few dollars more they just make sense.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-10-2008, 09:52 AM | #15 |
DON'T TREAD ON ME
Before pulling the engine, I would suggest doing a compression check which should verify the condition of the rings and valve seal and if you have good oil pressure then the bearings should be good too.
Old Yeller |
11-10-2008, 11:38 AM | #16 | |
The carb im using is an old Edelbrock 600. It seems to work OK but its pretty beat up Last edited by LuckyHenriksen; 11-10-2008 at 11:39 AM. |
11-10-2008, 05:43 PM | #17 |
I wish I was a cowboy
I'll third the idea that it's all gonna come down to heads...although it may sound corny (and like I'm trying to sell you something), buy a combo head/intake/cam setup. Match your carb & headers to that.
Don't use stock vortec heads with a 280+ adv dur cam, or use Performer RPM heads in an engine you're afraid to spin past 4000 rpm. Don't use an RPM intake with a little 262 cam and stock heads (well that one probably isn't so bad, but you see my point). Heads/intake/cam all work together. Get those to match the kind of driving you're going to do, make sure the converter & gears are a close fit, and you'll be happy.
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
11-10-2008, 08:16 PM | #18 |
Thanks ive been searching out some different heads. Hopefully I can find some affordable ones! How about ignition? Any advice on what to run with my rebuilt HEI?
11-10-2008, 08:53 PM | #19 | |
DON'T TREAD ON ME
The only way to know your compression ratio is to find out what size valve chambers are in your heads which can be determined from the casting numbers. Technically you also have to know what kind of pistons are in the engine but usually a fairly accurate guess can be made by just knowing the valve chamber size. EDIT: About the carb, IMHO Edelbrock carb and best performance don't belong in the same sentence. A RD 625 will make a noticeable difference by itself with no other upgrades. My brother has a '75 350 that came with a 600 Edelbrock. I gave him my old RD 625 and he can testify to the difference in performance. You aren't going to need anything beyond a 50,000 volt coil. At this stage of your build I wouldn't bother with MSD ignitions and the like.
Old Yeller Last edited by Old Yeller 1970; 11-10-2008 at 08:58 PM. |
