Old 11-10-2008, 01:55 AM   #1
mnky30
mnky30's Avatar
Question anyone have pics of rear sway bars
i am interested in installing a rear sway bar on my truck and was wondering if anyone has some pics of what they have do so i can get an ideal on how to install one. thanks
vinnie
1960 chevy c10 frame with a 1966 cab
2002 dodge intrepid r/t
2004 chevy 2500 4 door short bed
mnky30 is offline   Reply With Quote
Old 11-10-2008, 01:48 PM   #2
Chuck78
Re: anyone have pics of rear sway bars
use a 1980's Camaro rear bar from the yard, and make spacers for the frame mounts, as the Camaro frame is about 3" wider if I recall. If so, then you'd have to make 1-1/2" spacer blocks on each side. These are said to fit much better than even aftermarket models intended for our trucks, ESPECIALLY if lowered in the rear.
If you get a big IROC bar or one of the real fat ones, you will definitely need a REALLY big bar in front or else you will have oversteer/understeer issues for sure. Look for the smaller rear bar if you don't want to upgrade your front.
Chuck78 is offline   Reply With Quote
Old 11-10-2008, 05:34 PM   #3
Captainfab
60-66 Nut
The aftermarket rear swaybars for the '60-'72 trucks mount to the trailing arms and then link to the frame. Sorry I don't have any pics, I haven't got mine installed yet. If you want to upgrade or just add a bar to your front any front bar thru '87 will work, but the 3/4 ton camper specials and 1 tons had a larger 1 1/4" bar.
Old 11-10-2008, 11:25 PM   #4
mnky30
mnky30's Avatar
i have a front sway bar on the truck already it is from a 3/4 ton as is the hole front x-member and the rear diff shou;d i use a larger sway bar in the rear since i have a 3/4 ton one on the front already? thanks for the info
vinnie
Old 11-11-2008, 12:27 AM   #5
allen57
do u got any pics of ur setup?
allen57 is offline   Reply With Quote
Old 11-11-2008, 12:55 AM   #6
Frizzle Fry
Frizzle Fry's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=178261
Frizzle Fry is offline   Reply With Quote
Old 11-11-2008, 01:18 AM   #7
mnky30
mnky30's Avatar
thanks frizzle fry that is what i was looking for
vinnie
Old 11-11-2008, 11:03 AM   #8
vin63
It's Better With Nitro
vin63's Avatar
Here's a diagram from CPP...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-11-2008, 01:26 PM   #9
mnky30
mnky30's Avatar
thanks vin63 that helps
vinnie
