![]() Join Date: Dec 2007
steering doesn't work good on truck
I recently put a new steering box on my truck i then jacked the front of the truck off the ground put new ps fluid in and turn the wheel right to left several times, but when it is on the ground in park or moving slow you can't turn the wheels. Should you be able to turn the wheels when it is in park, if so any suggestions.
SKINNY TIRES RULE!
Re: steering doesn't work good on truck
Yes, you should be able to turn the wheels. Is the steering box for a 2wd or 4wd?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Its a 4wheel drive box on a 4wd truck.
SKINNY TIRES RULE!
Did you use the stock steering arm? Could you have an air bubble in the lines?
urban fourwheelin
with the engine running move the steering wheel lock to lock....repeatedly.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
I jacked it up and did that several times, my cap on the pump isn't very tight, could this be the problem. Any way you can unhook the line with it running to get out the air. if so which one.
A new box will 'eat up' a bunch of fluid. If the lock to lock doesn't get it, drive it some, do some u-turns etc and check the fluid.
I assume you have the egine running when it's in park when you are trying to turn the wheels? |
urban fourwheelin
it can take awhile. how many is several times? 5 or 6? I'm talking like 50 times...I've had a lot of pumps take forever.....and don't unhook a line while it's running, you are asking for a big mess.
I'm a poor spectator
Yep lock to lock...HARD. Get out of the truck and pull on the steering wheel using the door to brace yourself while you pull like crazy. It sounds crazy but a local gearhead who rebuilds pumps and boxes told me that. It works too. Peridically check the fluid while your doing this too. Also, sometimes if it still won't work, turn the wheel one direction all the way and then turn the truck off and let it sit for a few minutes and let the air work it's way up, then turn it back on and turn the wheel the other way and turn it off again and do the same thing. This works well too.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
It doesn't whine when it is setting running, it does a little when i try to turn the wheels.
#13 |
