Hello i just bought a 60-63 cab for a rat rod project and i was wonder if anyone can tell me if i can use a 64 66 frame or if i need to find a 60-63 frame?It seems like i can find 64-66 everywhere but the 60-63 frame are few and far between.Any info would be great.Thanks Shaun
Re: Cab and Frame
I have a 61 Cab on a 65 Fleet frame. Seems to have bolted right up.
Re: Cab and Frame
Thanks that is what i needed to know because i can get a 66 frame for 250 ready to paint today so that helps alot.... Great looking truck BY THE WAY
#4 | |
Re: Cab and Frame
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
Re: Cab and Frame
Thanks,
I live fairly close. If you ever need help with anything shoot me a note. |
Re: Cab and Frame
You may want to look under your truck and see if the cab mounts have been relocated. If they have not then you have a 63' cab and a 61 grill.
Re: Cab and Frame
My cab mounting holes appear to be 4' apart from each othe and 14" from the outside of the cab..If that sound right?
Re: Cab and Frame
A cab from a 60-62 will not bolt right up to a 63-66 frame...as others have said the mounting locations are different. I bolted a 63 cab onto a 64 frame...it fit perfectly.
#9 | |
Re: Cab and Frame
Re: Cab and Frame
http://www.americanclassic.com/paint.htm?p1=vin This site says my cab to be a 1962 but with the measurements everyone is saying it's a 63 now i'm lost.....
#11 | |
Re: Cab and Frame
Re: Cab and Frame
It's still there with the origanal rivets???
#13 |
Re: Cab and Frame
I measured a 62' cab and a 63 cab.
62' front cab mounts are 53-1/4" C/C & 7-1/4" from kick panel to C/ of mount. 63' front cab mounts are 41-1/2" C/C & 13" from the kick panel to C/ of mount.
