Old 11-10-2008, 12:20 PM   #1
Oklahoma
6 ton press
Hey guys, I'm looking to buy a 6 ton press, and was wondering if that would be enough to press bearings, ball joints, ect. I don’t want to buy one that wont be big enough to do the job, and I don’t want to buy one that will be more than I will ever nee. What's your opinion?
Oklahoma is offline   Reply With Quote
Old 11-10-2008, 12:46 PM   #2
HotRodYJ
HotRodYJ's Avatar
Re: 6 ton press
6 ton sounds very small. I have a 12 ton and it's almost not enough sometimes. When the presss wont do it, I end up adding heat to get the job done. I imagine a 6 ton would only handle the easiest of jobs.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 11-10-2008, 12:49 PM   #3
Oklahoma
Re: 6 ton press
Thanks HotRod, that's what I was looking to know.
Old 11-10-2008, 01:13 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: 6 ton press
Most of the pressing that I have done could be done with a 10 or 12 ton press. That includes bearings up to 4" and ball joints. But it does not include wheel studs. IIRC, we were up around 30 tons to get some old studs out of a 9" rear.
With an 80 ton press, the only time I had too much press was putting a gear on a camshaft. Bigger isn't always better, but it certainly helps.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-10-2008, 01:18 PM   #5
Oklahoma
Re: 6 ton press
Thanks Fred
Old 11-10-2008, 02:53 PM   #6
HotRodYJ
HotRodYJ's Avatar
Re: 6 ton press
Originally Posted by Fred T View Post
...we were up around 30 tons to get some old studs out of a 9" rear...
You should have removed the wheel and lug nut first
Old 11-10-2008, 02:59 PM   #7
Oklahoma
Re: 6 ton press
Yea, I just used a BFH, to get the studs out.
