11-10-2008, 01:47 PM | #1 |
Alright Alright Alright
12 bolt diff cover leaking
The other day i noticed that my differential cover on my 12 bolt rear was leaking. I had changed the fluid in it not too long ago and i heard here on the forums that most guys dont use a gasket and just use silicone (which i did). I took the cover off, cleaned the surfaces, applied a bead of silicone and new fluid. Today when i came out to my truck, it was leaking again. How thick is the bead of silicone suppesed to be? How long should i let it cure before i reinstall it? What do yall think?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
11-10-2008, 02:55 PM | #2 |
Re: 12 bolt diff cover leaking
leaking rear covers is mostly due to overtightening of the bolts //they requirs 45INCH pounds of torque more causes the holes in the cover to dimple out causing leaks//i still believe in the original style gasket with a light coating of permatex avaition sealer
11-10-2008, 03:03 PM | #3 |
Use "the right stuff", it is appropriately named gasket in a can. It keeps what you want in and what you don't want in out.
11-10-2008, 08:21 PM | #4 |
I have a torque wrench i can use. Does that mean that its 3.75 foot pounds?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies Last edited by crm318; 11-10-2008 at 08:22 PM. |
11-10-2008, 08:26 PM | #5 |
sorry i dont know the proper way to convert inch pounds to ftpounds//i've got different torque wrenches for bboth
11-10-2008, 08:30 PM | #6 |
67-72 Addict!
Yes
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-10-2008, 08:39 PM | #7 |
Moderator
Very informative...I am having the exact same problem with my 12 bolt rear...I am SURE I have overtightened the bolts. I guess it is just like valve covers.
11-10-2008, 08:46 PM | #8 |
I take the stock gaskets and put a thin coat of RTV on both sides...and spread it out with my fingers... wouldn't hurt to let it cure for a bit then refill it and go driving...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 11-10-2008 at 08:47 PM. |
11-10-2008, 08:50 PM | #9 |
When you clean the surfaces to be sealed ,I use brake clean or something similar so there's no oil residue. I also let the silicone dry over night or a couple of hours before adding oil. Chris
11-10-2008, 10:32 PM | #10 |
Yea, i think i tightened the hell out of them (well more than 3.75 foot pounds). ill inspect the surfaces and do it correctly tomorrow. Thanks guys.
