11-10-2008, 08:08 PM | #1 |
Which sway bars will fit?
Searched but didnt find the answer I'm looking for.
Will 73-87 2WD sway bars fit my 67 2WD step? Was there ever a rear sway bar for this application? And what mods must I make to ensure front/rear sways fits properly? Thanks all! |
11-10-2008, 09:58 PM | #2 |
Too Dumb To Know Better
Re: Which sway bars will fit?
Yes the front sway bars will fit. I've put 2 on from mid 80's trucks. Can't help you on the rear.
11-10-2008, 10:03 PM | #3 |
Young Gun
i had a similar question to yours. What sway bars will work for a 1970 c/20 4x4 with a solid front axle?
11-10-2008, 10:21 PM | #4 |
87-95 Nissan Pathfinder rear sway fits perfect on a leaf truck. Its the exact width of the frame so you don't have to weld brackets like the Camaro bar. Its one inch diameter. It should fit the coil over rear also. $12 at Pull a part.
11-10-2008, 10:23 PM | #5 |
Also the 3/4 ton Suburbans had the biggest front sway bar up to 91. I installed one on mine.
11-10-2008, 11:24 PM | #6 |
Adam B
I found a front sway bar off a 3/4 ton truck and it worked out great. I forgot the size, but it is also the same on the 1 ton truck.
I got mine at pull-a-part for $10. I also grabbed a rear sway bar from an 82-91 camaro. I haven't installed this yet, but have heard good things. Below are the links for the camaro install. http://67-72chevytrucks.com/vboard/s...highlight=sway http://67-72chevytrucks.com/vboard/s...d.php?t=178261 |
11-10-2008, 11:24 PM | #7 |
Adam B
