11-10-2008, 09:51 PM | #1 |
where to hook up pcv? my new radical 427bbc
hey guys, so i just bought a new motor for my67 swb. its a very radical 427 bbc. rec. heads, solid cam ect. my question is that it has a team g intake with no ports for any kind of manifold vacuum. my carb has the one off back, which i put to my power brakes. where should i hook up my pcv? thanks!!
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
11-10-2008, 10:12 PM | #2 |
Re: where to hook up pcv? my new radical 427bbc
drill and tap a hole on the intake itself.
myspace.com/southtacomaalleyrally |
11-10-2008, 10:38 PM | #3 |
What cam do you have? I have a radical 427 that only pulls 5"s vacuum. So i went ahead and converted to manual disc brakes, and it stops better than my power drum brakes that i used to have in it with a small block.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
11-10-2008, 10:43 PM | #4 |
Sierra Grande Club
If your intake is installed I don't think I'd drill into it, but try a tee on the line going to your power booster.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
11-10-2008, 11:01 PM | #5 |
Get a alum. carb spacer with hole for a barb fitting.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
