Old 11-10-2008, 10:45 PM   #1
woodhe1
newbe
i just purchased a 1963 gmc 4000. I am looking at installing a power steering conversion unit. Where do i begin? thanks dan
woodhe1 is offline   Reply With Quote
Old 11-10-2008, 10:51 PM   #2
mnky30
mnky30's Avatar
Re: newbe
welcome here are some web sites to look at www.lmctruck.com www.ClassicParts.com www.paddpckparts.com www.harmons.com and you should look for a ps box and pump from a late 70's early 80's 2wd 1/2 ton truck
vinnie
1960 chevy c10 frame with a 1966 cab
2002 dodge intrepid r/t
2004 chevy 2500 4 door short bed
mnky30 is offline   Reply With Quote
Old 11-10-2008, 11:33 PM   #3
LILRED66
LILRED66's Avatar
Re: newbe
Dan:
Welcome to the forum from Kansas City, KS.
I have done the power steering conversion on several of my own 4-5-6 Chevy trucks with a V8. It is a moderately simple conversion and requires the following:
Power steering conversion kit, including the frame backing plates and mounting hardware.
Saginaw power steering pump, mounting brackets and hardware ('68-'86).
Saginaw power steering gear box with high pressure and return hoses ('68-'86).
Rag joint (correct splined end to fit the power steering gear box).
Pitman arm (correct to fit the power steering gear box).
"V" belt for power steering pump.
The complete kits are available at:
www.carsteering.com
www.classicperform.com
The power steering conversion brackets are available at:
www.classicparts.com
www.lmctruck.com
www.bowtiebits.com
and several other aftermarket truck parts suppliers.
I have also purchased the complete kit on eBay.
When purchasing the complete kit, as well as the conversion bracket kit, you will be provided with a good set of "play-by-play" instructions...which will help you with the modification.
I prefer the complete kit from Classic Performance Products or carsteering.com, because they take all the guess work out of determining which parts are needed and are compatible with each other. I have purchased the complete kit for under $500.00 and although it was a little pricey, it was worth it because I didn't make numerous trips to the auto parts store for hardware, hoses and belts.
Good luck with your project and I hope this information is helpful.
PS: All of the above information pertains to a 4-5-6 Chevy truck and may or may not apply to your GMC.
LILRED66 is offline   Reply With Quote
