11-10-2008, 10:57 PM | #1 |
np205
Hello!
I'm looking for the specs on the bolt/stud that the 4x4 floor shifter pivots on that is attached to the adapter that connects the np205 with the manual transmission. 1972 chevy 3/4 ton. If anyone knows where I can get one great, otherwise I will mfg one Many Thanks Last edited by orangeblossomspecial; 11-10-2008 at 11:05 PM. |
11-11-2008, 01:58 AM | #2 |
Re: np205
I have two currently in my garage with the two shifters that go with them (I dont know which I am going to use yet, both from sm465/np205's as far as I know). I dont know where you could buy one, possibly someone on the board here has an extra one.
The one on the top is for an older style adapter, I believe, it uses a 7/16 - 14tpi 2 1/2" long bolt (with a few washers) The one on the bottom is I assume a newer style, 9/16 - 11 tpi 2 5/16" overall long. It has a 3/4 x 1 1/2 shoulder with a 1/2 x1/16 groove for grease. This set up seems to have a lot of sideways slop in the shifter, I may need to drill out and add a bushing to the lever. I hope this helps some.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" Last edited by eric67m; 11-11-2008 at 02:03 AM. |
11-11-2008, 09:25 AM | #3 |
Re: np205
I got one from manes- it's under "motor, cab & misc. mounts"
http://www.manestruckparts.com/store...Category_ID=16 Also found this old thread- http://67-72chevytrucks.com/vboard/s...t=shifter+bolt
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited Last edited by Ace in the hole; 11-11-2008 at 09:29 AM. |
11-11-2008, 10:36 AM | #4 |
Re: np205
Many Thanks again,
Appreciate the pictures and found what I needed at Manes |
