Old 11-10-2008, 10:59 PM   #1
Blazedup
Disc brakes from a 87 burb
I just bought a 1987 Suburban 4x4 for next to nothin. I'm wondering if I can adapt the disc brake system, rear end(6 lug) and 700r4to my 69 C10 2wd that currently has 6 lug power drum brakes on it. What will I need to get this done?
I want drop spindles and the newer style tranny xmember. Would it be better to put the engine(tbi) and tranny(700r4) from the burban into the 69 or just the tranny. Any help would be great.
Blazedup is offline   Reply With Quote
Old 11-11-2008, 09:59 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Disc brakes from a 87 burb
Your question is a bit confusing so let me see if I can break this down-
Donor- 1987 Suburban 4x4
Recipient- 69 C10 2wd
Front brakes- You want to adapt the disc brake system to your drum brakes. Since your trying to swap 4wd to 2wd I don't see this as being a fit. You might be able to use some of the components, but not all.
Rear end-(6 lug) It can be done, but unless you have a leaf spring rear you are going to need to swap all the mounting brackets. They are welded on, so it will require some fabrication skills.
Transmission- You don't say what motor you currently have, but the 700r4 will bolt to any small block. I am not sure what is required to adapt the newer style tranny xmember.
Would it be better to put the engine(tbi) and tranny(700r4) from the burban into the 69 or just the tranny? That depends on the condition of the motor and tranny. Id the TBI motor is low mileage, it's worth the swap. If you don't want the TBI then you can buy a carb intake for it as well.
I want drop spindles- Your best bet is to buy a disc brake conversion from one of the many forum vendors. I "think" they offer a 6 lug conversion with drop spindles. You will need to verify that to be sure.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-11-2008, 12:04 PM   #3
Blazedup
Sorry that my thread was confusing, let me explain further.
Yes
I'm looking to use the rotors, calipers, dust shields,brake lines, master ect from the burb. Are there drop spindles avail that will allow me to use these parts on my 69 that currently has drums? I just rebuilt the front suspension on the 69, so spindles that allow me to use my current ball joints and tie rods would be nice.
I have a coil spring rear and will need to weld on new mounting brackets. Aer these avail from a board sponsor, or where can these be purchased?
I have a 383 SBC
The engine is really strong and appears to be in good shape. How do I adapt the wiring for the TBI to the 69?
I bought the burb inorder to use the disc brake components and rear end(just rebuilt with 373's) on my 69.
Again sorry for any confusion. I just hope I can use the parts for what I intended. If not, the bruban runs and drives great, just needs new paint and tires. It's lifted about 12 inches so It would cost me quite a bit to replace those 38's and I really don't need another project. Any help on adapting the burb parts to my 69 truck will be much apreciated.
