Old 11-11-2008, 12:02 AM   #1
50adrod
50adrod's Avatar
steering column length
I want to install a flaming river or ididit tilt column with the shift on the column. what length should it be? I know it would be better to have my seats but I dont yet and need to make up the linkage and cut the new firewall so i can paint the cab.
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 11-11-2008, 12:13 AM   #2
mr48chev
mr48chev's Avatar
Re: steering column length
I would think your best bet would be to dummy up a column with either the wheel you intend to use or one of similar dimensions and then take some measurements. unless you mount it back in the stock position and then adjust for the depth of the wheel I don't see how you can get a comfortable fit without having the seat of choice in there to get a really good feel of things.
Old 11-11-2008, 12:45 AM   #3
50adrod
50adrod's Avatar
I will mount it where the stock column was. they make various drop mounts if i need to bring it down more. maybe I need to go seat shoping at the local u pull it yard
Old 11-11-2008, 12:52 AM   #4
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
If you must do this without the seat the best bet is to buy a tilt column. That will give you more flexibility if your just guessing where it should go.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 11-11-2008, 07:45 AM   #5
50adrod
50adrod's Avatar
yes it will be a tilt column, what is the height to the top of the stock bottom seat cushion? I will be building mounts for the bucket seats so I can control the height. thanks
Old 11-11-2008, 01:52 PM   #6
OrrieG
OrrieG's Avatar
I really think you need to get your seats first. I am starting to deal with the same issue; I have the column and seats and am going to wait until I have the cab back on the frame to mock it up. I have found to much variance vertically and horizontally to try and guess. I am using a 74 truck tilt column and 05 Yukon third row seat. You can adjust where the bottom goes through the floor/firewall, the column drop at the dash, distance from the floor to steering wheel, height of seat, distance of seat from the dash and wheel, and rake of the seat. Moving one affects the rest and clearances in the engine compartment to headers, steering boxes, brake boosters and lines. If you look at the build threads, the steering is usually one of the last things figured out when all of the fixed stuff that can be affected is installed.
OrrieG is offline   Reply With Quote
Old 11-11-2008, 02:36 PM   #7
50adrod
50adrod's Avatar
yes I think I will just wait until I get the seats. I just would rather have cut the hole before I painted the firewall because after the cab is bolted down and the engine is in you can not get to the firewall for paint.
