Old 11-11-2008, 01:14 AM   #1
camaney
How to lower 67 gmc with leafs
Ok i have 67 gmc and i want to lower de rear it has leaf springs i was wondering who has pictures of a flip and what do i need. I dont know how to weld do they sell a kit with no welding required? Thanks
camaney is offline   Reply With Quote
Old 11-11-2008, 01:19 AM   #2
Cyclone
Cyclone's Avatar
Re: How to lower 67 gmc with leafs
Welcome from another Northern Cal user. The flip will put your axle on top of the spring, I think I still have a kit I bought and didn't use. I'll check the shed after work tomorrow and let you know.
The kit I have is similar to this one.
Cyclone is offline   Reply With Quote
Old 11-11-2008, 01:46 AM   #3
jsbgump
Gone Fishing
jsbgump's Avatar
Call up ECE andthey will have everything you need.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 11-11-2008, 08:29 AM   #4
There are a few options depending on the drop desired.The axle flip for the most.I`m not sure of the exact measurement.Figure the height of the axle and spring pack.ECE makes lower springs for a couple inckes,I think.There are replacement spring hangers that lower mounting points an inch or two.Longer shackles give 1/2 the extra length.Some take leafs out to fine-tune.You can use combinations of these methods for a given height.
Old 11-11-2008, 12:15 PM   #5
Livrat
Member #1049
Livrat's Avatar
I am in the midst of lowering my GMC as we speak and have discovered, If you use the flip kit it will give you almost an 8 inch drop and you will have to "C" notch the frame, Brothers trucks has a "mono" leaf spring that will give you a 4 - 5 inch drop, (kinda spendy at $400), longer shackles will give a 1 - 2 inch drop, I havent seen the replacement sping hangers yet.. Special-K who has those??
So far I have cheated, (just because I had the parts laying around) I used spring hangers and springs out of a 72 Blazer 4X4, put the axle on top of the springs and it gave me the exact ride height I was looking for. (it does take some drillling and mods to the front hangers)
Livrat is offline   Reply With Quote
Old 11-11-2008, 01:06 PM   #6
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
ECE sells 4" drop leafs for $299.00 a pair. That would be a bolt-in mod, no welding required.
They also sell 1-1/2" drop shackles for $59.00.
So for $360 in new parts, you could drop is 5-1/2".
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-11-2008, 04:24 PM   #7
camaney
so if i go the kit in the picture do i need a c notch? thanks
Old 11-12-2008, 12:29 AM   #8
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
My 72 has leaf springs and a c-notch. It was dropped when I got it, but it looks as if the springs were de arched and a leaf taken out. They also turned the big thick one upside down. I saw a jig on the HAMB that someone made to de-arch a model A spring. They used a small jack to do the job. The same thing could be done with your truck springs for cheap.
low'n slow is offline   Reply With Quote
Old 11-12-2008, 12:47 AM   #9
paisaloco67
I wouldn recomend this set up. Its either just the leafs or the shackles, I used them both to get the max drop and the truck rode like s*** ! I ended up taking the shackes off.
paisaloco67 is offline   Reply With Quote
Old 11-12-2008, 01:38 AM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
What made it ride so bad? Was it bottoming out on the frame?
Keith
Convert to disc brakes.
Old 11-12-2008, 01:44 AM   #11
paisaloco67
It didnt bottom out, the ride got very stiff when I put the shackles on, I know
kinda weird but with the shackles off, the ride was a lot better.
Old 11-12-2008, 08:21 AM   #12
I`ve seen them for`73-ups.A friend put them on an`84.I`m sure they can work on earlier trucks.Maybe not quite bolt on.I don`t think he bought from LMC,but I think he said they carried them.
Old 11-12-2008, 11:33 AM   #13
Orange
Licensed to Thrill!
Orange's Avatar
I went with the ECE lowering leafs only in mine.
Ride is considerably rougher than stock, but, I guess you are gonna pay the price with leafs.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
