Old 11-11-2008, 05:38 PM   #1
gottwake
gottwake's Avatar
Is this bag supposed to compress more?
I assumed the bag would compress at least down to the 2.5-3.0 range. Its a dominator 2600. The fitting is open and no other blockages and there is no motor in the truck as of yet. There is roughly 2" under the frame. It did lay on the ground.
Blazer Project
gottwake is offline   Reply With Quote
Old 11-11-2008, 06:48 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Is this bag supposed to compress more?
That looks about right to me. Towards the inside, you are about 3" compressed. Only bag I know of that will compress more is a Firestone. You may need to run a cup instead of a plate...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-11-2008, 06:58 PM   #3
hotrodhomi
hotrodhomi's Avatar
I agree, a cup will get you lower. If you change to '73+ a arms you gain a little clearance too. THe frame shouldn't hit the ground unless you have other mods. The a arms are the lowest part in the front. My a arms hit the ground and all I have are spindles and bags, but I used cups, not plates.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 11-11-2008, 07:07 PM   #4
gottwake
gottwake's Avatar
So I should just bust out the plasma cutter and cut hole large enough for two cut pieces of pipe and weld them in, right? Good thing I just had the arms and stuff painted.
-Thanks
Blazer Project
Old 11-11-2008, 07:16 PM   #5
Shane
Shane's Avatar
do the dominators have internal bumpstops like the slam specialties?
Shane is offline   Reply With Quote
Old 11-11-2008, 08:07 PM   #6
hotrodhomi
hotrodhomi's Avatar
I don't know about the dominators ,but I run Slams with cups and my A arms can kill ants.
'66 impala ht
Old 11-11-2008, 08:16 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
Any profile shots of your wheels to see how low you are?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-11-2008, 10:01 PM   #8
leftcoast66
leftcoast66's Avatar
Cup will most definitely help. That looks to me like its internally bumpstopped w/ how high it sits, must be like you guys were saying w/ the slam specialties.
leftcoast66 is offline   Reply With Quote
Old 11-12-2008, 09:13 PM   #9
gottwake
gottwake's Avatar
I'm going to add cups this weekend and then I will update you guys. Any idea how much wider the cup has to be than the bag? The bag is 8"W
Blazer Project
Old 11-12-2008, 10:53 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Wake they aren't talking about making pockets, they are talking about mounting cups to the bags.
Like these-
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-12-2008, 11:03 PM   #11
joe231
joe231's Avatar
yeah, but....
you can get lower if you mod the arms and weld a piece of pipe in the arm.
your bags are 8" in diameter? most I have seen use 8" pipe, but i don't think your bags will work with it.
how can you get any lower with cups that sit in the pocket, versus the plates he has.
seems like it would be a minuscule amount
CHEVY ONLY
Old 11-12-2008, 11:14 PM   #12
jlaird
jlaird's Avatar
yes, you are correct, about a .25"-.5" tops. If you want to get substantially lower, you will have to cut the pockets in your arms like you mentioned.
jlaird is offline   Reply With Quote
Old 11-12-2008, 11:17 PM   #13
joe231
joe231's Avatar
that is what i figured, thanks for the info
CHEVY ONLY
Old 11-12-2008, 11:46 PM   #14
TylerHuff
TylerHuff's Avatar
the i.d. of the pipe is 8 inches. it would be tough to put a bigger pipe in the arm and still have the bag centered
1987 Gmc sierra
1962 Apache 10
TylerHuff is offline   Reply With Quote
Old 11-12-2008, 11:47 PM   #15
gottwake
gottwake's Avatar
Hey "J",
Got it.
Blazer Project
Old 11-13-2008, 12:20 PM   #16
ENHANCED AIR RIDE
No that is the way they are, it looks good. And no fear on the damaging bag bottomed out, there darn near bulletproof. We have a customer that has had them on his 64 Impala for 8 months now slamming and hopping it with no ill effects.
ENHANCED AIR RIDE is offline   Reply With Quote
Old 11-13-2008, 08:34 PM   #17
hotrodhomi
hotrodhomi's Avatar
I hope he doesn't kill someone when he wrecks his ride because his bag breaks from riding on empty bags with out bump stops.
'66 impala ht
Old 11-13-2008, 09:22 PM   #18
VA72C10
VA72C10
VA72C10's Avatar
Yeah, I looked online and it appears they don't have the internal bumpstops. They will lift a little higher and possibly a little shorter, but the disadvantage in their slightly softer ride is that they baloon out more and can rub more easily than the stiffer slam bags
Old 11-13-2008, 09:32 PM   #19
ENHANCED AIR RIDE
nevermind...
Old 11-14-2008, 01:59 AM   #20
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Dunno if you plan to cut your lower A-arms or not, but if so here is a link to the ones I did
http://67-72chevytrucks.com/vboard/s...=251067&page=2
Starts at post #34
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-14-2008, 02:27 PM   #21
gottwake
gottwake's Avatar
well done..I am actually. Going to get the material today. As a matter of fact.
Blazer Project
