Tire Sizes
Ok I know you should not put two different size tires on the same axel. But while in four wheel drive will it be ok to have a pair of 31x 10.5x15 on front and 32x10.5x15 on rear. The only reason this would happen is if I needed to use as a spare. Not the smartest thing but in a emergency will it cause any damage to transfer case or axels????
Re: Tire Sizes
Not in 4wd.It could blow the gears out of the front or screw up the driveshaft,not sure about the driveshaft part maybe someone will chime in on that one but the gears i'm sure about.If you run it in 2wd with the hubs unlocked you should be ok.
#3 | |
![]() Join Date: Nov 2006
Re: Tire Sizes
![]() but more importantly, it looks funny and people will not think you are cool ![]() |
Re: Tire Sizes
Yes I know kinda stupid but dont have a spare yet and want to do some wheeling. Thank for the info guys.
Chevys Kick A$$
Re: Tire Sizes
I don't recommend it man. Its not good on the truck!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#6 | |
Re: Tire Sizes
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
