I have a 69 Chevy CST but doesn't have ac or power brakes but has all the trim.(cst?) Has a 396,th400 tran, Dana 60 posi 4.56 rearend, leafspings, one piece drive shaft. The real kicker is that the block is 4 bolt main with 375hp closed chamber heads. all this is factory. Have build sheet. everyone that as seen it says no way. whats the deal?
It sounds like a real decent truck for sure. The four bolt main... seems odd too. You have the suffix code numbers on the block? One piece drive shaft too seems odd should be a two piece. If you have a build sheet for the truck built that way it's a great find and a source of proof to the doubters on original equipment. Could you scan the build sheet and send it to me... would like to see it. Not doubting you... just would like to see it. Rod
chevytruckranch@hotmail.com [This message has been edited by Rod (edited May 11, 2002).]
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
CST Z84 option has nothing at all to do with other optins such as J70 and N40 and so forth that you mentin that it does not have, all Z84 is is a comfort and appearance option, it means chrome trim and carpet and little things like that, like silverado and Custom Deluxe does
And G80 could be had with 396(L47) without the 4 speed tranny, Maximum Traction(G87) was with 396 with the 4 speed only ------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 *many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham current fleet: -71 C-10 350/CH465/3.07- basketcase, #1 -90 Cavalier 2.2L sky blue, a driver -84 Z28 5.0L/700R4/3.73 daily driver -84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2 -82 purple Trans Am, project #3 *Paint is overrated* © RSS Enterprises 2000 [This message has been edited by Fast68Chevy (edited May 11, 2002).] |
its all about the +6 inches
And I have seen 1 pce shafts on shortbeds.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough? Columbus Ohio |
