Old 11-11-2008, 11:58 PM   #1
daveodom
daveodom's Avatar
converting to power rack and pinion?
I'm in the process of bagging my 64' c-10. I have already z'd the front clip 4" and the rear 10". I have also moved the engine/tranny back about 10". My question is: I was wanting to convert to a power rack and pinion set-up. What is the rack that I want? Mustang II? What is the rack that Porter uses? Anyone done this with the stock crossmember? Also I have narrowed my control arms 1 1/2" on each side and moved the ball joint forward 1" to center the wheel in the wheel well. Thanks for any info/pics.
Dave
daveodom is offline   Reply With Quote
Old 11-12-2008, 12:46 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: converting to power rack and pinion?
Here's the rack I use with the Dropmember:
http://store.summitracing.com/partde...5&autoview=sku
Keep in mind the location of the racks pivot points and distance between pivot points all needs to be in harmony with the control arm and ball joint pivot points and distances between them. Otherwise there will be some ill steering effects.
Not sure if this rack will even work right with your application.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-13-2008, 05:58 PM   #3
daveodom
daveodom's Avatar
Thanks there porterbuilt! Do you know if the stock chevy steering pump works well with this rack? Always have had the manual steering and this powersteering thing is new to me. Thanks again.
Dave
Old 10-02-2009, 12:00 AM   #4
c10Mang
c10Mang's Avatar
Hey Dave,
Did you ever figure this out? I wanted to know if the stock pump would work too.
thanks..
c10Mang is offline   Reply With Quote
Old 10-02-2009, 01:15 AM   #5
PBFAB.COM
PBFAB.COM's Avatar
Dave
Here's the story everybody will tell you on the factory pump and Ford rack:
The valving in the GM pump is incorrect for the Mustang rack. There are pressure reducers you can use to correct this.
Here's what I have experienced:
On ALL the installation I have done, I have not had to use a pressure reducer... the steering felt great. The rack was not too quick, or too slow... just right. Not sure if it was mere luck... or maybe I was doing something wrong? But there was no need for a pressure reducer.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-02-2009, 05:56 AM   #6
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
also will the stock adjusting sleeves work or do you need someting different thanks
gostranger is offline   Reply With Quote
Old 10-03-2009, 09:43 AM   #7
gostranger
gostranger's Avatar
i am also interested in doing a rack on the stock crossmember any info????
