Old 11-12-2008, 12:07 AM   #1
Funeral
Funeral's Avatar
Square Bolts and Flat Heads.... Kill me.
Ok guys whats the trick?
Air Hammer - 0 / Rusty Fender bolts - 1
I tried the ole air hammer on these bolts because they were an impossible move, I got one to break off and was really excited, sharpened my air hammer bit... and 20 mins later despite the earplugs I was def and the bolt was still staring at me... I think they are made of adamantium or something.....
So whats faster? Air hammer? or grinder?
These are rear fenders btw... fronts were a breeze.
Funeral is offline   Reply With Quote
Old 11-12-2008, 12:27 AM   #2
pugs
pugs's Avatar
Re: Square Bolts and Flat Heads.... Kill me.
i break out the hot wrench to get bolts lose
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 11-12-2008, 12:30 AM   #3
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Bolts on the frame or heavy gauge steel I use a sharp chisel to knock the head off then a punch to drive it through. BTW the chisel is about 18 long and the punch is 16/18". For the fender bolts I use a grinder and punch.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 11-12-2008, 12:36 AM   #4
Funeral
Funeral's Avatar
Grinder and a punch sounds like the trick. I just fear grinding through the back fender well bolt wall but I guess as my mother used to tell me "Then be careful"
Hot wrench? Maybe you can shine some light on that for me. unless you're talking about the torch and torque.
Old 11-12-2008, 01:11 AM   #5
pugs
pugs's Avatar
yes the torch actually i have just a small bottle of map gas that use and it works everytime for me
Old 11-12-2008, 02:50 AM   #6
72lb4x4
Heat preferably on the nut mostly, but it helps on either and a shot of penetrating type oil, and/or tighten them til they shear off. Sometimes they fight...
72lb4x4 is offline   Reply With Quote
Old 11-12-2008, 04:34 AM   #7
Funeral
Funeral's Avatar
made some decent progress tonight ended up grinding off and tapping them out, clean job, some were a pain kinda welding themselves in there, but all worked out good.
Old 11-12-2008, 12:34 PM   #8
1956cameo
1956cameo's Avatar
Grinding is usually the best route to go. I hate grinding but as long as sparks are flying you know you are making progress.
1956cameo is offline   Reply With Quote
