Next project: 1970 K10
For the life of me I can't find my notes on what year of S-10's o get the weatherstripping from to fit our trucks, or for the 3-point seat belts. Anyone?
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
Moderator
![]() Join Date: May 2007
Re: What year S-10 for door weatherstripping and seat belts?
I think the weatherstripping is from S-10's concluding in 93...
Beautimus, thanks!
![]() Join Date: Nov 2004
1st gen square body. I think it's 82-93. It worked OK for me, but I feel that my doors shut too hard still. This was with used weather stripping too that's been on the truck over 2 years now. I can't adjust my doors out anymore, the body lines wouldn't match up.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 11-12-2008 at 02:12 PM. |
Moderator
I have heard the S-10 weatherstripping is a bit too tight as well. Check with Wes from Classicheartbeat. He sells and recommends the Dodge Dakota weatherstripping. Same as the S-10 stuff, but a little less tight and lets the door shut easier
Dakota, OK. Thanks!
I can't remember the s-10 seatbelts either and I really want to get a set. I know it's not off the extended cabs, I think just the regular cabs.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
I agree on passing on the S-10 stuff Bob, come over and try my doors, I have them.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
67-72 Addict!
What year Dakotas?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
whats the reason for not going original..
my build http://67-72chevytrucks.com/vboard/s...d.php?t=210902 |
The S-10 and Dakotas use pinch molding to attach the seal to the body, instead of using weatherstrip adhesive.
Chris I will do that. I still need to go for that "test ride" too. ![]()
You can use seat belts out of an S10? Sweet what year? Does it attach to the stock location in our old trucks?
#13 |
#14 | |
Out of the carpool lane.
Anyone got a pic of this Dakota weatherstripping?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#15 |
MY EX DRIVES A BROOM
i wanna know about the dakota weatherstripping too!
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
#16 |
Sweet brad Ill look for it
I went and looked and only found your guide to modifying the belts to fit "nutrition friendly" people ![]() Is there another one that I am not finding? Last edited by LuckyHenriksen; 11-13-2008 at 10:45 PM. |
#17 |
I just bought weatherstirp from Wes. I am not sure of what it was intended for as it is what he has listed for my 71 online. looks good though. I had to get a new windshield rubber and decided to get the door rubber at the same time.
#18 |
mini truck racer
How did it fit . I have the full size 88-98 rubber and it is to tight .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#19 |
Anybody know about the seatbelts?
#20 |
I sent Wes an email asking about the Dakota weatherstriping. I'll keep looking for the S-10 seat belt option.
#21 | |
Basically, they just bolt in the same place as the originals including the B pillar. It's a no brainer, but hard to make the ds work with tank in cab as shown below. Here's a pic of a buddies belts up top. Mine are the lower profile style below and I think they look better. From my observations it seems that the best ones come in Oldsmobile Bravadas, but I'm not sure the exact year- right around the mid 90's.
#22 |
Ok thanks Brad. Ill be cruising the local CL to see if I can find any. Do they just not fit between the gas tank and door?
#23 |
You won't find them at all on CL. You need to go to the U-pull by your house. But on used belts, always take into consideration the condition of the vehicle and any major damage to it. You probably don't want belts that were in a major fender-bender. Otherwise if it just appears the vehicle is relatively fine, then you'll be ok.
As you can see in the pic, a special adaptor plate was needed to offset the base from the tank. Even when they were in like you see, the belt didn't want to retract all the way and was kind of annoying. If you don't have the tank inside, then you can just literally bolt them in all the original holes and they work great!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 11-14-2008 at 02:56 PM. |
#24 |
Ok sweet I love a good junkyard scrounge. So look for mid 90's beater cars? Not S10's?
#25 |
While any belt may work, we're talking about S-10 belts here. I'll go back and edit a bit more.
